2000 500 missing - Polaris ATV Forum
post #1 of 11 (permalink) Old 05-10-2019, 01:41 PM Thread Starter
hoyb31's Avatar
2000 500 missing
All right guys I have been messing with this thing for awhile now can't get it right. It's a 2000 sportsman 500 I have replaced all the fuel lines fuel filter fuel pump, checked the cam and valve clearance. I have cleaned and tuned the carb 3 times. Changed the plug, new air filter new intake boot 7 name I have changed and or replaced it. I will attach a video of what it's doing. https://youtu.be/pEGRIDtjmnY
Any and all help will be appreciated
hoyb31 is offline
post #2 of 11 (permalink) Old 05-10-2019, 02:11 PM
stave7119's Avatar
Sounds like it is not getting enough air or too much fuel. Did it sit for a while before it started doing this?
Could be a mouse nest or other restriction in the exhaust. Maybe throw the muffler on a hot fire for an hour.
Hers: 2007 Sportsman 500 EFI, Polaris Winch, 26" Bear Claw HTRs on Moose 427x Wheels. QSC Clutch Kit, Hand Warmers
2001 Magnum 325 Warn winch and Moose 60" plow
SOLD 2004 Sportsman 600 Twin
stave7119 is offline
post #3 of 11 (permalink) Old 05-10-2019, 02:45 PM Thread Starter
hoyb31's Avatar
It did sit not sure how long before I picked it up. That's the only thing I haven't checked it does push the exhaust out good
hoyb31 is offline
post #4 of 11 (permalink) Old 05-10-2019, 03:17 PM Thread Starter
hoyb31's Avatar
Pulled the muffler of its about 90% better think I have to go back and readjust the carb for the better breathing
hoyb31 is offline
post #5 of 11 (permalink) Old 05-21-2019, 09:02 AM Thread Starter
hoyb31's Avatar
Update. So I put a new carb kit on and still have the sputtering. It ran good for about 4 minutes then started again. Need some help guys
hoyb31 is offline
post #6 of 11 (permalink) Old 05-21-2019, 10:30 AM Thread Starter
hoyb31's Avatar
So I just cracked the airbox lid and the sputter goes away. Going to adjust my air screw out half turns at a time and see if that helps
hoyb31 is offline
post #7 of 11 (permalink) Old 05-21-2019, 01:03 PM
You don't have an air screw, you have a fuel screw - adjust it in 1/4 turn at a time to lean it out, but it only affects idle - for the open throttle problem you need to go to a smaller main jet to get to run the same as taking the air box lid off - what size main jet does it have in it presently?
2006 Trailboss 330
2002 Sportsman 90
2005 TRX400EX (FOR SALE)
2004 CRF250X
1979 Honda CBX (6 cylinder)
1981 Kawasaki KZ305-A
1989 Honda VT1100C
latebird is offline
post #8 of 11 (permalink) Old 05-21-2019, 01:14 PM Thread Starter
hoyb31's Avatar
I will have to look at it again. I changed out the air box lid with an extra on I had and it runs good. Has a slight hesitation as u throtel up
hoyb31 is offline
post #9 of 11 (permalink) Old 05-21-2019, 01:17 PM Thread Starter
hoyb31's Avatar
The old jet sayes 4HB41. On it same as the new needle that cam with the rebuild kit
hoyb31 is offline
post #10 of 11 (permalink) Old 05-21-2019, 02:20 PM
That's not the jet, that is the slide needle - the slide needle mates with the needle jet (the needle jet is commonly referred to as the emulsion tube or main jet holder) the main jet is what secures the needle jet in the carb body.
But if you have it running satisfactorily just by changing the air box lid, don't sweat it, just ride it.
2006 Trailboss 330
2002 Sportsman 90
2004 CRF250X
1989 Honda VT1100C
latebird is offline
Looking for 06 450 motor compatibility kcmng Polaris Sportsman 20 05-09-2019 05:40 AM
Sportsman 600 Primary Help Needed TooSlo ATV Repair and Maintenance 8 07-23-2018 11:58 AM
