Engine Won't Start - Page 2 - Polaris ATV Forum
post #11 of 13 (permalink) Old 05-19-2019, 02:05 PM Thread Starter
dkarr13's Avatar
I can definitely tell a difference in the fuel line so I don't believe that's the issue so I'm back on the carb.. I soaked it in carb cleaner, saw daylight through the jets, and slapped it back in and still didnt get it to fire. Is there anyway I can get an OEM carb without paying $450? Or maybe somewhere that I can try to slap an OEM carb to see if that's the issue?
dkarr13 is offline
post #12 of 13 (permalink) Old 05-20-2019, 06:27 AM
Nope - we are back to compression - how many PSI does the engine have when cranking over with the throttle held wide open?
latebird is offline
post #13 of 13 (permalink) Old 06-17-2019, 03:11 PM
greenteame's Avatar
Im in a similar boat. Ive got a 2005 polaris ATP 500ho and seems to have a weak spark to me. New cheap carb, new fuel pump, Measured 500v from the cdi out, tried a different stator / pickup with the same results (185 ohms on trigger and 0.3 on stator), different coil pack (0.2 on primary and 12k on secondary, adjusted valves to 0.006, compression is 50 on stone cold and 70 with a little oil. Swapped ECM, Is it just the low compression numbers? Factory service says 50 - 100 psi. The kicker is I do not have the original cluster but was told it ran without it but no 4x4. It has been sitting for around 4 years. Starter fluid doesnt seem to have any impact.
Thanks for any help and sorry if I hijacked. Didnt see him responding and really need some expert advice.
greenteame is offline
Looking for 06 450 motor compatibility kcmng Polaris Sportsman 20 05-09-2019 05:40 AM
2008 Polaris sportsman 500 flywheel chidwick89 ATV General Discussion 1 05-02-2019 07:46 PM
VIN - Sportsman 500 or 500 HO? das86turbo ATV Repair and Maintenance 7 01-02-2019 06:58 AM
2015 Sportsman etx barely will run, pops, stalls PaYankee Polaris Sportsman 12 10-21-2018 04:38 PM
