Polaris ATV Forum (https://www.polarisatvforums.com/forums/)
-   ATV Repair and Maintenance (https://www.polarisatvforums.com/forums/atv-repair-maintenance/)
-   -   '04 sportsman 600 twin idle & trottle dies (https://www.polarisatvforums.com/forums/atv-repair-maintenance/182737-04-sportsman-600-twin-idle-trottle-dies.html)
jorswift 05-15-2019 04:34 AM
Hey all. New to the site. I have a 01 Polaris 500, but I am helping a buddy with his '04 600 twin. Bought it at auction from an owner we knew. knew it was rolled and had some things fixed. But the darn thing seems temperamental. On cold startup it will idle ok with choke but when you give it gas, it bogs down and wants to die. It will run ok with the choke on. It does this until it is warmed up. It can take several minutes for this, even during 60* day. Once it is warmed up, it seems to run fine.
I took the cab off and cleaned. Drained gas tank and put new fresh gas in. checked air filter, air box, snorkel. Replaced both plugs. I checked the intake manifold, cant seem to see any leaks. What should the air/fuel needle be set to? What about float measurement?
Any ideas? I read that this particular model has some ignition issues, but I wouldn't think it would be the issue since it runs fine after warm up. Thanks for the help.
latebird 05-15-2019 07:36 AM
Check the compression - engine cold (65 to 80 degrees F) throttle wide open - it's probably still a carb problem
jorswift 05-15-2019 08:36 AM
I just ordered the 157.5 main jet. I will try switching that out and backing the pilot adjuster out a bit.
polman500 05-15-2019 08:49 AM
Yep, low compression will do that.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
