Choke cable staying closed - Polaris ATV Forum
post #1 of 2 (permalink) Old 05-22-2019, 04:24 PM Thread Starter
Adam200's Avatar
Hello first time here. I am working on my 2016 Polaris Phoenix 200. I took the carb off for a good cleaning, when I put it all back together I noticed when I have the choke in the closed position and try to put it into open the cable doesn't move with the lever. Anything helps thanks.
Adam200 is offline
post #2 of 2 (permalink) Old 05-22-2019, 06:28 PM
stave7119's Avatar
I had one a while back that did that. I found that from the lever end the cable ran into a box where 2 cables could be connected. The cable connection inside that box had come unhooked so the cable didn't work.
Hers: 2007 Sportsman 500 EFI, Polaris Winch, 26" Bear Claw HTRs on Moose 427x Wheels. QSC Clutch Kit, Hand Warmers
2001 Magnum 325 Warn winch and Moose 60" plow
SOLD 2004 Sportsman 600 Twin
stave7119 is offline
Common Carb Issues pfunk76 ATV Repair and Maintenance 117 03-30-2019 08:09 AM
phoenix 200 choke cable Jpcjguy ATV Repair and Maintenance 0 03-09-2019 12:39 PM
Choke Cable 12mm Nut Tip! ATRCo12 ATV Repair and Maintenance 4 02-20-2018 10:52 AM
Sportsman 300 Choke Cable gyroman Polaris Sportsman 1 11-14-2017 07:35 AM
Polaris 325 choke cable DIZZYBIKER Polaris Trail Boss 0 07-31-2016 09:30 AM
