2004 sportsman 400 frame/engine cable - Polaris ATV Forum
post #1 of 5 (permalink) Old 06-10-2019, 02:54 PM Thread Starter
troy.sandstrom's Avatar
Hello all, i am fairly new to the atv world. I recently purchased a 2004 sportman 400 and it needed some work. I have it mostly finished but i have no idea where the frame/engine ground cable connects. If anyone has any idea where this cable goes on this four wheeler I would greatly appreciate it and put you in my prayers. A pic. would be excellent if anyone has one. I know it is located above the water pump but unsure exactly where it is suppose to go, Thanks all.
troy.sandstrom is offline
post #2 of 5 (permalink) Old 06-10-2019, 02:58 PM
g.m.p.'s Avatar
Hey my friend i have 2004 polaris sportman 500 4x4 I can help you with that But also i need your help with mine I need solenoid wiring pic If you can definitely i can help you just send me a pic.! Of what you need
Enviado desde mi iPhone utilizando Tapatalk
g.m.p. is offline
post #3 of 5 (permalink) Old 06-10-2019, 03:43 PM
If its a ground just put it under any bolt that's convenient. I think they often are under one of the starter mounting bolts.
polman500 is offline
post #4 of 5 (permalink) Old 06-11-2019, 04:49 AM
Solenoid wiring is easy - cable to starter motor goes on one terminal and the battery cable and accessory wires go on the other terminal - the terminated wires attached to the solenoid plug into the wiring harness
2006 Trailboss 330
2002 Sportsman 90
2005 TRX400EX (FOR SALE)
2004 CRF250X
1979 Honda CBX (6 cylinder)
1981 Kawasaki KZ305-A
1989 Honda VT1100C
latebird is offline
post #5 of 5 (permalink) Old 06-11-2019, 05:12 AM
g.m.p.'s Avatar
See this picture I put arrows So you can see how is mine but Is not working I replace for a new solenoid and i put the cables And works few times and no crank Now The cable with question mark for some reason Is turning the fan on So i put the switch cable on battery And now i have power but no crank But if i put the Screw driver Battery to starter The stater works Can you wrote a pic. How is the way supposed to go Just to put it back the way you tell me and exclude That Am the 3rd owner And the previous owner Wire the solenoid but i donít know he did the right way thanks here is the picture
g.m.p. is offline
