97 xplorer front hub torque spec - Polaris ATV Forum
post #1 of 5 (permalink) Old 06-12-2019, 05:28 PM Thread Starter
Mascola222's Avatar
Can someone tell me what the torque specs in ft pounds are for the castle nut inside the front hub with the Hillard clutch thanks in advance it’s a 500 sorry forgot to add that
Mascola222 is offline
post #2 of 5 (permalink) Old 06-12-2019, 06:06 PM
Its inch pounds... about 115 in.lbs. That is less than 10 ft.lbs. Just a barely snug. Spin the wheel and tighten then loosen then tighten again till just snug but wheel still turns easily spinning the wheel all the while.
polman500 is offline
post #3 of 5 (permalink) Old 06-13-2019, 05:09 PM Thread Starter
Mascola222's Avatar
Ok thank you I’m having an awful time with this wheel new clutch and armature plate new bearings new seals and the magnetic coil seems to be working as it should but I can still stop the front wheel easily I’m out of ideas
post #4 of 5 (permalink) Old 06-14-2019, 06:31 AM
Sometimes it just takes an experienced mechanic to solve the problem. You might have a worn or damaged part that you haven't discovered yet or perhaps used a wrong lubricant preventing the unit from working properly.
2006 Trailboss 330
2002 Sportsman 90
2005 TRX400EX (FOR SALE)
2004 CRF250X
1979 Honda CBX (6 cylinder)
1981 Kawasaki KZ305-A
1989 Honda VT1100C
latebird is offline
post #5 of 5 (permalink) Old 06-14-2019, 06:55 AM Thread Starter
Mascola222's Avatar
I don’t disagree but I changed every part and used Polaris demand drive oil so I don’t know what else a mechanic can tell me
