Idle is high after I give it gas! 2006 Trailboss 330 - Polaris ATV Forum
post #1 of 6 (permalink) Old 07-20-2011, 09:20 AM Thread Starter
vaporzz's Avatar
Hello Folks,
First I wanna say I am glad to have found this forum! As I have read through some of the help you good people have givin us Newbs is just amazing!! Anyway I just picked up in very nice condition, a 2006 Trailboss 330! This thing runs sweet, great power and amazingly smooth on the balcktop no shimmy or shake or smoke! The first problem I had was the Idle, as I would letoff of the throttle it would die! Problem solved! I slipped off the boot on the throttle cable and backed it off a couple of turns and now it starts right up and idles Great! So yesterday I take it for a spin after I had fixed what I thought was the only issue with the bike, I go around the block come back pull into the garage and set the bike in neutral and then the problem starts! the idle while in neutral started steadily climbing higher and higher, so before the rpms could go to high I cut the machine off! So I go Hmmmm, So I started the bike back up and first clik starts right up, ok so everything kewl idleing good not climbeing! as soon as i tapped onto the throttle to give it gas and revv it up a couple of times and let it go, bike starts to climb in idle again, Higher and gradually higher like sumthings sticking, so I cut off bike before it gets to high! Folks anyhelp would be apprecitated your thoughts on resolving this issue, I am mechanically inclined also, I really love this bike and if I could whip this issue this thing will be a sweet rig, Thanks folks! JR
vaporzz is offline
post #2 of 6 (permalink) Old 07-20-2011, 01:51 PM
Bruce! is offline
post #3 of 6 (permalink) Old 07-20-2011, 02:34 PM Thread Starter
vaporzz's Avatar
Bruce! I just got this Rig and I'm real Happy with it! I'm in the garage righ now messin with the cable I'm sure that's the prob! It can't be to technical!!! I hope! JR
vaporzz is offline
post #4 of 6 (permalink) Old 08-11-2014, 02:50 PM
frankkop's Avatar
Was it the cable?
frankkop is offline
post #5 of 6 (permalink) Old 08-11-2014, 07:00 PM
RVS Performance's Avatar
You adjust the idle with the screw on the carb, not by tightening the cable. The carb slide is probably hanging by the cable and not closing all the way to let it idle down.
RVS Performance is offline
post #6 of 6 (permalink) Old 08-13-2014, 03:05 PM
frankkop's Avatar
Thank you sir... I will try it out..
frankkop is offline
ok lets see who is god here, trailboss wont idle or comeup to ful throttle rekd65 ATV Repair and Maintenance 5 10-16-2012 04:54 PM
04 Sportsman 600 high idle motonick34 ATV Repair and Maintenance 1 06-20-2011 04:56 PM
High Idle issue, air box question Willyt07 Polaris Scrambler 4 04-28-2011 01:45 PM
high idle when hot half_full ATV Repair and Maintenance 0 12-13-2010 10:53 AM
Very high idle on 99 bigboy 500 norville ATV Repair and Maintenance 2 04-17-2010 02:27 PM
