04 700 efi - Polaris ATV Forum
post #1 of 7 (permalink) Old 06-16-2019, 04:56 PM Thread Starter
pokey's Avatar
04 700 efi
Im needing to replace my outer rear cv boot right side [sitting on machine] my question is how do I pull the axel? I thought it would come apart like the front but nooo am I missing something or is it really stuck in the diff. I just didn't want to break another part. Thanks Guys.
pokey is offline
post #2 of 7 (permalink) Old 06-16-2019, 05:00 PM
FPD218's Avatar
You need to take the brake Caliper off first to remove the right rear axle.
JUNE 2017 & SEPTEMBER 2018 POLARIS FORUM ATV OF THE MONTH WINNER
2019 Sportsman 850 SP Premium
Removed all Warning Decals
3500# Polaris Winch W/Synthetic Rope
Winch Stopper Cable Line Saver
ATV-GURU.COM Front and Rear Bumpers
2" Receiver in Front Bumper
Kenda K587 HTR Bear Claws 26X9X14 & 26X11X14
Ultimate Series Windshield Fairing, Mid & Low Height Windshield
New Style Polaris Lock & Ride Rear Storage Box
Garmin GPS176C, Ram Mount
Polaris Rear View Mirrors
4" Front Rack Extender
Center Brake/Tail Light LED
Rear LED work lights/strobes
Built on March 27 2019
Purchased New April 13 2019 0.1 Hr .2 Mi
Power Sports Abrams, Wi
SOLD
2006 Sportsman 800 EFI Twin
Purchased new to me on Aug 08 2016 97Hr's 811Mi
Sold Apr 07 2019 231 Hr 3126 Mi
https://www.youtube.com/watch?time_c...&v=k6Nlb_qRoeg
"I am the majority!"
*WEAR A HELMET, I'M LIVING PROOF THEY WORK!
FPD218 is offline
post #3 of 7 (permalink) Old 06-16-2019, 05:07 PM Thread Starter
pokey's Avatar
I got that off but I thought I was missed something the axel wont or don't want to budge its never been off .
pokey is offline
post #4 of 7 (permalink) Old 06-16-2019, 05:17 PM
First spray the splines full of PB Blaster so it can soak while you get everything else out of the way. Get the caliper, hub and bearing carrier off. Tie the upper arm up out of the way. Sit down in the floor and hold the axle straight in line with the differential. Get a good grip on the shaft and cv with both hands and brace your foot on the frame. Push it all the way in and then give it a sharp jerk to pull the axle out. You then out the axle in a vise to get the cv off the shaft. Some just knock off and some have a spring ring that must be spread with a special set of pliers.
If that don't work post back and we'll give you some alternative methods to pull the axle out.
polman500 is offline
post #5 of 7 (permalink) Old 06-21-2019, 03:20 PM Thread Starter
pokey's Avatar
thanks men I just back on it today we quit early to bale hay then got rained out so in the shop I headed to get this thing back together. I assume the the cv end is the end that was in the differential.
pokey is offline
post #6 of 7 (permalink) Old 06-22-2019, 07:32 AM
Sorta, the end in the differential is technically called a plunge joint if I'm not mistaken and the outer one is a cv. Regardless of the name, you need to get the axle out to disassemble the cv and put a boot on it.
post #7 of 7 (permalink) Old 06-23-2019, 06:28 AM Thread Starter
pokey's Avatar
Thaks Polman for the help.
pokey is offline
