2004.5 sportsman 400 no spark - Polaris ATV Forum
post #1 of 3 (permalink) Old 06-22-2019, 05:06 AM Thread Starter
Nickburns's Avatar
I recently bought a 2004.5 sportsman 400 from an old timer. It had 304 miles on it. So I couldnít pass it up. About a month after I bought it I was riding with my buddy and it died after going thru some mud. I changed the plug in the field and still not starting. Pulled the plug back out to see if I could see a spark and nothing still. I got towed home and started reading up. My background is in residential hvac service not vehicles but I understand electrical systems and can read diagrams and use a meter. How hard could it be. Long story short I ended up changing the stator and pulse coil. I didnít use a oem stator as the price is ridiculous. I went with one from rm stator. Put it all back together turned it over and zilch. It turns over just no spark. I was sure that i was going to be victorious. I should have started tracing back from the plug to the ignition coil and went from here before buying the stator. But, the resistance I got across the pulse coil (w-wr) was 168 ohms and it was supposed to be 97. I notice the recoil handle was not completely seated the day I got towed home. When I pulled the recoil cover off it had a bit of moisture, rust and a few tiny spring looking things that I still donít know where they cam from. So I changed it.
Now that this repair isnít working I am looking to the ignition coil. I read resistance across primary to ground last night and I have 0 ohms. I still need to pull the front end plastic off to really get the ignition coil off the machine and check the plug wire. I am just looking to see if anyone else has any advise of where/what else to look at. Thanks in advance.
Nickburns is offline
post #2 of 3 (permalink) Old 06-22-2019, 06:04 AM
By the VIN - is it an 04 or 05?
latebird is offline
post #3 of 3 (permalink) Old 06-22-2019, 10:24 AM
ragdude's Avatar
My first guess would be the ecm, they had bad luck with them back then.
Protect the 2nd Amendment; it's the original homeland security act!
Bio fuel is the future; bring it home to the American farmer.
2005 Polaris 400 4x4
frt/rear rack extenders
Warn winch
front/rear bumpers
temp gauge
reverse light mod
heel clicker kit
lock-n-ride windshield
lock-n-ride gun scabbard
lock-n-ride rear hard box + side bags full of whatever I might never need, plus
Occasionally chased by a small trailer with more camping gear... good grief
2002 Trailboss 325
Front storage box
Rear storage bag...
I'm ready for a
ragdude is offline
