2008 Sportsman 800 drive belt problems - Polaris ATV Forum
post #1 of 6 (permalink) Old 07-10-2019, 01:44 PM Thread Starter
Invisibleman145's Avatar
My drive belt keeps blowing up about once a year. I’ve had it for 4 years and it has been consistently around 10-12 months after I change the belt that it just basically blows up and chunks of it are all over in the cover and the string wraps all around the clutch. I’m finally getting sick of having to buy a new belt and replace it so often and I want to get to the bottom of this issue. I thought it was the way I drive it but I’ve been using low gear a lot more when I should and it still goes bad so could something be wrong with the clutch and if so how would I go about fixing it?
Invisibleman145 is offline
post #2 of 6 (permalink) Old 07-11-2019, 06:58 AM
bp405's Avatar
Tell us more!! You running bigger tires??? Lot of mud?? How many miles n hrs on the machine? You definitely have a problem!!!
2011 Sportsman® 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsman® 570-T
2019 Aluma® A8818
bp405 is offline
post #3 of 6 (permalink) Old 07-11-2019, 08:41 AM Thread Starter
I think the tires are 22 inch. I have 3,972 miles and 315 hours on it. I don’t do too much mudding. I ride in open dirt fields a lot but not when they are too wet. It’s a lot of road and grass driving.
post #4 of 6 (permalink) Old 07-11-2019, 12:32 PM
Heat is usually what kills a belt and causes it to explode. Check that your air ducts are not obstructed and that clutch alignment is good. Misalignment and scrubbing on one side of the sheaves creates excess heat hardening the belt compound over time. The hardened belt will then crack leading to catastrophic failure at high speed.
polman500 is offline
post #5 of 6 (permalink) Old 07-11-2019, 01:52 PM Thread Starter
I will check the ducts and make sure that is all good. How would I go about checking the alignment myself?
post #6 of 6 (permalink) Old 07-11-2019, 02:11 PM
bp405's Avatar
It sounds like your clutches need to be rebuilt!!!!
QSC clutch kit
added 7 zerks
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
2019 Aluma® A8818
bp405 is offline
