2005 700 EFI issues - Polaris ATV Forum
 2Likes
post #1 of 15 (permalink) Old 07-28-2019, 07:58 PM Thread Starter
Iceman26's Avatar
2005 700 EFI issues
Last weekend while out having fun ended up tipping ATV on its side. Before this happened the machine was running well but once we tipped it back upright the machine will turn over and fire up but will backfire through air cleaned whwn gas it applied. Machine will idle for 30 seconds and die but then will fire right up. Anyone have troubleshooting advice as to what to do to fix machine.
Iceman26 is offline
post #2 of 15 (permalink) Old 07-29-2019, 08:01 AM
Try purging air from the fuel rail - release the fuel pressure from the rail where the pressure gauge would be connected - once bled, cycle the fuel pump on till it shuts off, then turn the key off and back on to cycle the pump on and off again - repeat 4 or 5 times and try running it again - if that doesn't work, check the fuel pressure - the pump may have been damaged if it ran dry while tipped.
Iceman26 likes this.
latebird is online now
post #3 of 15 (permalink) Old 07-29-2019, 08:29 AM
bp405's Avatar
Chk your oil level and you may need to remove the spark plugs and turn the machine over to "blow" out the combustion chamber.
2011 Sportsman® 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsman® 570-T
2019 Aluma® A8818
bp405 is online now
post #4 of 15 (permalink) Old 07-29-2019, 07:27 PM Thread Starter
Iceman26's Avatar
Thanks Latebird. Gave it a try and still not wanting to run. Will fire up and idle but popping and sputtering
Will have to get gauge to check pressure
Iceman26 is offline
post #5 of 15 (permalink) Old 07-29-2019, 07:28 PM Thread Starter
Iceman26's Avatar
Thanks bp405. Will try tomorrow when I get home. Changed the plugs out but did blow out chamber
Iceman26 is offline
post #6 of 15 (permalink) Old 07-30-2019, 04:45 PM Thread Starter
Iceman26's Avatar
Purge fuel rail and blew out chamber and still not running well. Will fire and idle for a while but any gas causes it to sputter and die
Iceman26 is offline
post #7 of 15 (permalink) Old 07-30-2019, 05:20 PM
bp405's Avatar
Chk for any codes.
QSC clutch kit
added 7 zerks
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
2019 Aluma® A8818
bp405 is online now
post #8 of 15 (permalink) Old 07-30-2019, 07:53 PM
Throttle
When you give it air by opening the throttle, the fuel system is not doing it's job and supplying the increased air flow with the proper amount of fuel - the trick is to figure if it's supplying too much or too little fuel
post #9 of 15 (permalink) Old 07-31-2019, 07:25 PM Thread Starter
Iceman26's Avatar
Got code 54. Looking for what to check now that I have a code
Iceman26 is offline
post #10 of 15 (permalink) Old 08-01-2019, 05:01 PM Thread Starter
Iceman26's Avatar
Ok guys. Engine temperature lamp fault! Would that actually cause running issue with the machine. Where or what can be done to correct other than disconnect battery and reset code?
Iceman26 is offline
