05 sportsman 700 efi - Polaris ATV Forum
post #1 of 15 (permalink) Old 08-11-2019, 03:16 PM Thread Starter
hoyb31's Avatar
I just picked up a 05 sportsman 700 efi. It has no spark. The guy I bought it from replaced everything but the stator. As I am going through the wiring I noticed to cut wires going to the coil and have no ideal where they go.theres a 3 pin connector that s plugged in a green and white dot, a red and black dot, and yellow and brown dot. Then there's a bare wire that s cut and a red wire that s cut. That s the 1st pic. On the other side of the harness the red wire is cut again and the bare wire is connected to a ground. Does anybody know where the red wire should be shocked into on both side?. Or have a wiring diagram they can share with me.
ID:	119515   Click image for larger version
hoyb31 is offline
post #2 of 15 (permalink) Old 08-11-2019, 03:43 PM
bp405's Avatar
Any idea what component the wires go to come from??
2011 Sportsman® 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsman® 570-T
2019 Aluma® A8818
bp405 is online now
post #3 of 15 (permalink) Old 08-11-2019, 03:46 PM Thread Starter
hoyb31's Avatar
No I can't find another cut wire the red wire that comes out the back side looks like it should hook into should hook into a group of red wires that go into the ecu.
hoyb31 is offline
post #4 of 15 (permalink) Old 08-11-2019, 03:52 PM Thread Starter
hoyb31's Avatar
Doesn't make sense to have a fuse that only has power on one side either. The group of red wires comes into the 6amp fuse but nothing come out the other side of the fuse
hoyb31 is offline
post #5 of 15 (permalink) Old 08-11-2019, 04:53 PM
bp405's Avatar
Yeah it's funny how it's wired but if you look closer at the side with no wires, there's a "bridge" in there that feeds the circuit.
QSC clutch kit
added 7 zerks
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
2019 Aluma® A8818
bp405 is online now
post #6 of 15 (permalink) Old 08-11-2019, 05:05 PM Thread Starter
hoyb31's Avatar
Yes I seen that after a closer look it was bridged. I just don't know where those 2 wires go. I seen on older post guys had the same thing but they didn't get an answer. I guess I'll have to buy a service manual for it.
hoyb31 is offline
post #7 of 15 (permalink) Old 08-11-2019, 05:19 PM
bp405's Avatar
Hold on before you buy a manual. There are guys on here that have e-manuals that will send it to you. Hold out a bit one of the guys will hook you up. In the meantime I'll do some looking around as will others to help identify those wires.
QSC clutch kit
added 7 zerks
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
2019 Aluma® A8818
bp405 is online now
post #8 of 15 (permalink) Old 08-11-2019, 05:21 PM Thread Starter
hoyb31's Avatar
Roger that. Thanks for the help. I also replaced plugs and cleaned all grounds and connectors today while messing with it.
hoyb31 is offline
post #9 of 15 (permalink) Old 08-11-2019, 05:39 PM
bp405's Avatar
Ok so I did some looking around and as crazy as this sounds I don't think the "cut" wires do anything. Well partially the cut bare wire is from what I gather a "drain" which filters out RF (radio frequency) aka cross talk or technically inductance. I've seen Polaris do some head scratching wiring deals and I'm partial to thinking this is one of those times. BUT we either need someone that knows exactly or the wiring diagram(s)!!!!
QSC clutch kit
added 7 zerks
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
2019 Aluma® A8818
bp405 is online now
post #10 of 15 (permalink) Old 08-11-2019, 05:42 PM Thread Starter
hoyb31's Avatar
Yes a wiring diagram would be great. But thanks again for the help. I am surfing around to find one but can't find one for the 05
hoyb31 is offline
