Dead Battery in 550 Sportsman - Polaris ATV Forum
post #1 of 7 (permalink) Old 08-13-2019, 11:19 AM Thread Starter
Rhawkins3.'s Avatar
Riding yesterday on my 2012 550 Sportsman and it died. Seems the battery was dead. Not sure why the battery died. Charged the battery and it seems fine, the bike is putting out 12.71 volts when running. Checked wires for obvious, breaks, shorts, blown fuses etc. Scared to go out on it and have it kill the battery again.
Any information about what to look for appreciated.
Had to get towed in by a Honda.
Rhawkins3. is offline
post #2 of 7 (permalink) Old 08-13-2019, 12:25 PM
bp405's Avatar
Yeah well that's the only time a Honda leads on the trail!!!!!!
Test the voltage running at 3,000rpm. I suspect a bad voltage regulator.
2011 Sportsman® 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsman® 570-T
2019 Aluma® A8818
bp405 is offline
post #3 of 7 (permalink) Old 08-13-2019, 12:30 PM
stave7119's Avatar
Test the battery first. Make sure it is good, then the charging system. Batteries used to give us a warning before they went bad..... slow crank, hard starting cold and so on. But not any more. They can go bad at any time for no reason. I parked my car in the garage on a Saturday night and sunday morning it wouldn't go. Goofy lights lit up on the dash. Bad battery. Compact yard tractor did the same thing.
2018 Kawasaki KLR650
SOLD 2004 Sportsman 600 Twin
stave7119 is offline
post #4 of 7 (permalink) Old 08-13-2019, 06:19 PM Thread Starter
Rhawkins3.'s Avatar
I checked the voltage at 3000 rpm, registers 12.71 volts. Battery is good also. Not sure where/what to check next. Took it for a ride this afternoon and it ran fine.
post #5 of 7 (permalink) Old 08-13-2019, 06:37 PM
FPD218's Avatar
Must be something in the water down in Illinois?
JUNE 2017 & SEPTEMBER 2018 POLARIS FORUM ATV OF THE MONTH WINNER
2019 Sportsman 850 SP Premium
Removed all Warning Decals
3500# Polaris Winch W/Synthetic Rope
Winch Stopper Cable Line Saver
ATV-GURU.COM Front and Rear Bumpers
2" Receiver in Front Bumper
Kenda K587 HTR Bear Claws 26X9X14 & 26X11X14
Ultimate Series Windshield Fairing, Mid & Low Height Windshield
New Style Polaris Lock & Ride Rear Storage Box
Garmin GPS176C, Ram Mount
Polaris Rear View Mirrors
4" Front Rack Extender
Center Brake/Tail Light LED
Rear LED work lights/strobes
Built on March 27 2019
Purchased New April 13 2019 0.1 Hr .2 Mi
Power Sports Abrams, Wi
SOLD
2006 Sportsman 800 EFI Twin
Purchased new to me on Aug 08 2016 97Hr's 811Mi
Sold Apr 07 2019 231 Hr 3126 Mi
https://www.youtube.com/watch?time_c...&v=k6Nlb_qRoeg
"I am the majority!"
*WEAR A HELMET, I'M LIVING PROOF THEY WORK!
FPD218 is offline
post #6 of 7 (permalink) Old 08-14-2019, 05:42 AM
bp405's Avatar
Change the voltage regulator!!! They can act erratic, be fine one time and wreck havoc the next. Your voltage @3,000rpm should be between 13.5-14.5vdc!!! The VR is definitely bad!!
QSC clutch kit
added 7 zerks
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
2019 Aluma® A8818
bp405 is offline
post #7 of 7 (permalink) Old 08-14-2019, 08:39 AM
Besides the rec/reg, check the AC volt output on the 3 alternator wires - should be above 30 volts at 2000 RPM
latebird is online now
