350L leaking coolant into crankcase...Headgasket? Waterpump - Polaris ATV Forum
 1Likes
  • 1 Post By stave7119
post #1 of 6 (permalink) Old 08-13-2019, 04:15 PM Thread Starter
DTLMG's Avatar
1994 Trail Boss 4x4 350L
Have not looked into it real deep yet, will pressurize cooling system first, initial research shows Head gasket, Waterpump gasket, waterpump bearing, or possibly broken water pump. Am i on the right track?
Veteran Techs please chime in. No sense to reinvent the wheel...at my age anyway.
DTLMG
DTLMG (Dave the lawnmowwer guy)
Currently performing CPR on 2001 Polaris Xplorer 250
2019 Polaris Ranger EPS
DTLMG is offline
post #2 of 6 (permalink) Old 08-13-2019, 06:22 PM
stave7119's Avatar
Hey Dave, post some photos when you get to diving into this one! We like pictures! And it is interesting to watch as you go through it. We get to learn with you.
Steve
FPD218 likes this.
2018 Kawasaki KLR650
SOLD 2004 Sportsman 600 Twin
stave7119 is online now
post #3 of 6 (permalink) Old 08-14-2019, 04:02 AM Thread Starter
DTLMG's Avatar
Steve
Will Do!
DTLMG is offline
post #4 of 6 (permalink) Old 08-14-2019, 08:32 AM
Head gasket is not normally the cause of coolant into the crankcase - water pump seal most likely
latebird is online now
post #5 of 6 (permalink) Old 08-18-2019, 04:59 PM Thread Starter
DTLMG's Avatar
Repair in frame or remove engine? Passed PSI PRESSURE Test?
I dove in a little deeper today, engine started right up and pee’d green on my garage floor. Removed the counter balancer drain plug and drained about four ounces of antifreeze out of it.
This is my first time doing surgery on a 350l. Is the water pump seal replacement easier with engine out of the unit? Pulling the motor sort of looks like a pain in the ass.. but so does trying to fix the water pump in the unit..
PRESSURE TEST OF COOLING SYSTEM...... I pressure tested the cooling system with 10psi introduced through the overflow tube adapter ( per Polaris tech manual) if the seals in the water pump are bad shouldn’t it lose pressure through the seals?
DTLMG is offline
post #6 of 6 (permalink) Old 08-19-2019, 10:25 AM
Yes, but sometimes they only leak when the pump shaft is turning
