Sportsman 850 running bad - Polaris ATV Forum
post #1 of 15 (permalink) Old 08-14-2019, 09:11 PM Thread Starter
97polaris500's Avatar
15 sportsman 850 will barely run starts rite up but idle jumps up and down and it backfire in the intake no check engine icon. Tps set to .67 volts tried different map sensor. Timing didn't slip just 2 months ago thought timing slipped so I pulled the motor and checked gear index and it was good had it welded. After getting her back together was running like crap and idling really high. With tps set to .67 just ran like crap, bottom the tps out one way it would idle okay but had no throttle response bottom tps out the other way witch was .39 volts idle and run good, but there has to be something wrong there any ideas? put 100 Miles on that trip no problem besides popping the stuck throttle code witch is weird cause I did the tiptie trick. Got back let the atv sit for a month and did power steering swap now starts rite up but has a surging idle and coughs and sputters when trying to hit the gas. Clean map reset tps to .67 and same thing pulled the plugs and looks like the pto cylinder is running lean. Any ideas where to start????? Please help
97polaris500 is offline
post #2 of 15 (permalink) Old 08-15-2019, 03:06 AM
SlowRoller's Avatar
I have no idea, but I do have the service manual for the 17/18 years, might be the same stuff, be happy to send it your way if you don't have a copy, just let me know your email!
Good luck!
18' 850SP
SlowRoller is offline
post #3 of 15 (permalink) Old 08-15-2019, 05:27 AM
Gmartino100's Avatar
Good luck!
I wouldn’t mind a copy. PM sent.
I'm not lost for I know where I am. But however, where I am may be lost. Pooh
Gmartino100 is online now
post #4 of 15 (permalink) Old 08-15-2019, 06:35 AM
Deucer's Avatar
Maybe check fuel pressure? My 1000 was real sensitive about having enough fuel pressure. Just guessing!
D
Deucer is offline
post #5 of 15 (permalink) Old 08-15-2019, 06:07 PM Thread Starter
I will check fuel pressure this weekend and report back after I do
post #6 of 15 (permalink) Old 08-16-2019, 10:02 PM Thread Starter
Havent had a chance to get a fuel pressure tester yet but did swap new injectors I had laying around same thing but what I did notice is after having it running and I pull the air box the pto runner and throttle biddy is full of exhaust gases. Is it possible that the valve adjustment I did before the last ride tightened up on the ride and now my intake valve is slightly open causing my issue??
post #7 of 15 (permalink) Old 08-16-2019, 10:08 PM Thread Starter
Or does anyone have any other ideas?? Idles erratic up down backfiring through intake, cough sputter and does when I hit the gas.
post #8 of 15 (permalink) Old 08-17-2019, 06:26 AM
Duse's Avatar
Hopefully one of the gurus will get you pointed it the right direction.In the mean time ,,,While in park Does the RPMs change when you turn handle bars ? Did you move or zip tie T/C wrong? Throttle cable adjustment ?
Whats a tiptie trick?
Duse is offline
post #9 of 15 (permalink) Old 08-17-2019, 08:22 AM Thread Starter
Yeah I did the zip tie in the throttle, adjusted throttle cable, changed map sensor, changed and adjusted tps, Iac valve seems to be working but does get quite warm, checked coil and spark plug wires, changed spark plugs I am at a lose. Only thing haven't done yet is check fuel pressure.
post #10 of 15 (permalink) Old 08-18-2019, 11:50 AM Thread Starter
Come on there has to be someone that can help with this issue??
