2002 850 touring cranks but no start, tried everything. - Polaris ATV Forum
post #1 of 5 (permalink) Old 08-20-2019, 09:00 PM Thread Starter
Whiterider's Avatar
My 2012 850 touring limited edition died on my last ride. I installed a new battery, and CPS sensor. Checked spark, and replaced plugs. Tested fuel injectors, pumping gas and has power to each one. When i add gas to the chambers it starts and runs, till the gas is gone. I checked brake switch, and can't find any wiring breaks so far. Fuses all good. I would bring into shop, but they have a month to two month waiting list. Any suggestions would be appreciated.
Pat
2012 EPS 850 Tour
Whiterider is offline
post #2 of 5 (permalink) Old 08-20-2019, 10:26 PM
bp405's Avatar
Did you do a fuel pressure test? You my be getting fuel but not enough.
2011 Sportsman® 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsman® 570-T
2019 Aluma® A8818
bp405 is offline
post #3 of 5 (permalink) Old 08-21-2019, 06:44 AM
Obviously it is not getting fuel - fuel pump is usually the culprit - check the fuel pressure
latebird is online now
post #4 of 5 (permalink) Old 08-21-2019, 12:25 PM Thread Starter
Whiterider's Avatar
Pulled the fuel bar and the injectors are squirting gas. I am unable to test pressure, but fuel cover the top of a plastic bucket lid.''
Thanks for the replies.
Pat
2012 EPS 850 Tour
post #5 of 5 (permalink) Old 09-01-2019, 11:12 AM Thread Starter
Whiterider's Avatar
2012 850 tour fuel pressure Check
Just received my fuel pump tester. Manual states it should be 43+/- 3. Pressure is 43. I guess its not fuel.
Pat
2012 EPS 850 Tour
