need help 2011 polaris 850 sportsman touring - Polaris ATV Forum
post #1 of 25 (permalink) Old 08-25-2019, 06:05 AM Thread Starter
rdallasc's Avatar
has anyone removed their fuel injectors to clean them?
if there clogged, what is the best method?
rdallasc is offline
post #2 of 25 (permalink) Old 08-25-2019, 07:42 AM
Simple - if the injector is clogged, replace it with a new one - they can't be cleaned adequately with solvents or additives.
How do you know they are clogged? According to all the sources I have available, the only way to clog an injector is to run dirty or unapproved fuel without a fuel filter, use sloppy or careless service procedures or leave the vehicle unused for a long period of time and injectors clogged from disuse will clean themselves if the engine will run and all the old fuel is drained, fresh fuel is in the fuel tank and the engine is operated normally for a period of time.
latebird is online now
post #3 of 25 (permalink) Old 08-26-2019, 05:37 AM Thread Starter
rdallasc's Avatar
yes, do agree with you
you latebird have been guiding me thtough this stupid machine,lol
i guess going to have to take your advice,and biting the bullet andtake to a service polaris center
dont really have the money, and ill always have tried to fix things on my own.
just a refresher,
ran it low on fuel, didnt run it out though.
few days later, put 3 gallons gas it it. hasnt started since
bought fuel pressure kit-40lbs with key on, 43 lbs while cranking
took off output line on top of fuel pump, with key on pumped gas for 3 secs, cranked it and pumped good stream
took plugs out, left hooked up,sparking against ground.
after struggling getting fuel rail unhooked, had to remove all that manifold below it to get to the two bolts that mounts the fuel rail
cranked over and looks like both injectors spraying fuel while cranking, i mean not a sh--t load, but spraying, yet no start
spray starting fluid in breather hole, it freaking starts!!!
im lost
rdallasc is offline
post #4 of 25 (permalink) Old 08-26-2019, 05:47 AM
bp405's Avatar
Fuel pressure sounds low!!! 55psi is what it takes to my knowledge!!
2011 SportsmanŽ 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 SportsmanŽ 570-T
2019 AlumaŽ A8818
2020 OutlanderŽ 1000R XXC (on order, ETA mid-Sept)
bp405 is offline
post #5 of 25 (permalink) Old 08-26-2019, 07:15 AM
Deucer's Avatar
Needs 58 psi
https://www.highflowfuel.com/i-22935...s-2204401.html
D
Deucer is offline
post #6 of 25 (permalink) Old 08-26-2019, 08:51 AM
Yep, just pumping is not enough. It MUST have the right pressure or you have nothing. It takes a good pump AND pressure regulator to have correct pressure. I suppose it can happen but I've never seen an injector needing replaced on one of these machines.
polman500 is online now
post #7 of 25 (permalink) Old 08-27-2019, 04:21 AM Thread Starter
rdallasc's Avatar
i got a copy of a 2011 year model-850cc service manual in pdf from this forum, and it said i believe 44psi
so im lost
rdallasc is offline
post #8 of 25 (permalink) Old 08-27-2019, 05:01 AM
so im lost
Hmm, I don't know about the earlier model 850's. I'll do some looking later today. I know my old 800 is 42 I think but my new 1000 is 58. Not sure when they upped the pressure. I was just saying you can't tell anything by just seeing that the pump is pumping. It and the regulator has to deliver at the correct pressure or you'll have problems.
post #9 of 25 (permalink) Old 08-27-2019, 05:09 AM Thread Starter
rdallasc's Avatar
if you good look for me that would be great,thanks!!
rdallasc is offline
post #10 of 25 (permalink) Old 08-27-2019, 07:33 AM
I just checked the 2011 850 manual 9923067 - specifies 43 psi
