Sportsman 500 rear stabilizer link bushings - Polaris ATV Forum
 1Likes
  • 1 Post By ricktmoore
post #1 of 5 (permalink) Old 08-31-2019, 06:00 AM Thread Starter
ricktmoore's Avatar
Question Sportsman 500 rear stabilizer link bushings
Anyone know the torque spec for the rear stabilizer link bushing bolts? Not noted in the manual. Maybe just tighten to visual compression shape? Thanks! 2001 & 2002 models if wondering.
ricktmoore is offline
post #2 of 5 (permalink) Old 08-31-2019, 08:23 AM
Torque based on bolt size - 8 mm bolt about 20 to 24 ft lbs - 10 mm about 30 ft lbs - can be higher for fine thread and lower on coarse threaded fasteners
latebird is offline
post #3 of 5 (permalink) Old 08-31-2019, 09:19 AM
bp405's Avatar
Not much!!! Just enough so you get a little compression in those bushings!!!!!
2011 Sportsman® 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsman® 570-T
2019 Aluma® A8818
bp405 is offline
post #4 of 5 (permalink) Old 08-31-2019, 02:37 PM Thread Starter
ricktmoore's Avatar
Thanks bp405. I was a little skeptical that latebird's reply offered a general rule-of-thumb, but likely didn't take into account this unique situation with those rubber bushings. Just 10 lb-ft of torque seemed to deform them too much. I really appreciate your advise!
bp405 likes this.
post #5 of 5 (permalink) Old 08-31-2019, 06:15 PM
17 ft. lbs. OP
polman500 is offline
