Battery died after 3 years... Battery suggestions??? - Polaris ATV Forum
post #1 of 29 (permalink) Old 09-02-2019, 03:17 PM Thread Starter
Paulish's Avatar
I have a 2016 570 Sportsman and my battery died.... Way out in the middle of nowhere in the mountains.
Luckily there was a guy with a 1000 Razor to tow me back...
Battery was pretty much empty of water... Not sure what happend there. I pretty much baby the thing and it stays in a heated garage over winter.
Anyway... I'm pretty sure polaris won't warranty a battery even though I have an extended warranty.
Any suggestions for a better / best battery?
Paulish is offline
post #2 of 29 (permalink) Old 09-02-2019, 03:23 PM
bp405's Avatar
By chance do you use a battery maintainer??
I like Odyssey batteries but a quality AGM battery will work!!
2011 Sportsman® 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsman® 570-T
2019 Aluma® A8818
bp405 is offline
post #3 of 29 (permalink) Old 09-02-2019, 03:25 PM Thread Starter
Paulish's Avatar
I don't use one in the summer... Usually stays on a trickle charger when I pack it up for the winter.
Paulish is offline
post #4 of 29 (permalink) Old 09-02-2019, 04:46 PM
bp405's Avatar
Chk the charger. Trickle type chargers do just that and don't shut off even after the battery is fully charged. Float chargers regulate themselves and turn on and off depending on their need.
Most likely the charger overcharged your battery and that's why the battery was low on water..
QSC clutch kit
added 7 zerks
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
2019 Aluma® A8818
bp405 is offline
post #5 of 29 (permalink) Old 09-02-2019, 05:07 PM
If the battery was dry you'd better check your charging system. 570 VRs are notorious for failure and often overcharge which will boil your battery dry.
polman500 is online now
post #6 of 29 (permalink) Old 09-02-2019, 07:36 PM
PoPo3's Avatar
Go with the AGM battery. Odyssey does not have the cold-cranking capacity (cold crank amps) of the AGM battery.
PoPo3 is offline
post #7 of 29 (permalink) Old 09-02-2019, 07:49 PM
What type of construction is the Odyssey battery? AGM is a construction (stands for Absorbed Glass Mat - a glass mat is placed between the plates to better withstand vibration and shock) - I use Yuasa AGM batteries.
latebird is online now
post #8 of 29 (permalink) Old 09-03-2019, 03:22 AM
bp405's Avatar
Odyssey batteries are only AGM!!
QSC clutch kit
added 7 zerks
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
2019 Aluma® A8818
bp405 is offline
post #9 of 29 (permalink) Old 09-03-2019, 07:41 PM Thread Starter
Paulish's Avatar
Yeah, I called my dealer today and they hinted to this...
If it was the charging system then battery and everything will be covered by my extended warranty.
Paulish is offline
post #10 of 29 (permalink) Old 09-04-2019, 03:58 PM
Poote's Avatar
Do not put another tiny motorcycle battery in your machine.
It is an easy fix to modify the battery holder to fit a lawnmower battery.
I use Autozone not NAPA
They are twice as powerful and built for rough use.
You can crank and crank that starter no matter what.
They cost less as well.
3 years is a good run for any battery.
Mud in your eye!
POLARIS the original CVT Transmission!
Poote is offline
