Hydrolocked sportsman 850 won't run quite right - Polaris ATV Forum
post #1 of 4 (permalink) Old 09-11-2019, 02:55 PM Thread Starter
tvr12speed3's Avatar
I got sucked into a hole and went deeper than I wanted to and the water sucked into my engine and shut off. I took it home and drained water from the clutch, the air box, pulled out the air filter, pulled out the spark plugs to push the water out, replaced the sorry plugs, changed oil few times (so far), plugged the clutch out, checked fuel pressure which was good (58psi). I pulled fuel from the top of tank, bottom of the tank, from fuel pump and from fuel rail, all were clean of water. At first it wouldn't run but now it will run at an idle while sounding like a misfire. If I touch the throttle at all it shuts off. I don't know what else to try to do. It doesn't sound like a bent rod
tvr12speed3 is offline
post #2 of 4 (permalink) Old 09-16-2019, 03:04 PM
Recon's Avatar
cam gear on the end of the crankshaft slipped.
Recon is offline
post #3 of 4 (permalink) Old 09-16-2019, 03:32 PM
shane-o's Avatar
Loosen air box from throttle body make sure intake is empty ...it has a low spot water can sit in
2015 xp 1000 black pearl,
-polaris front and rear bumpers
-polaris hand/thumb warmers
-polaris body guard
-gse slip on
-front diff fix
-cecco frame braces
-lock and ride front box.
-dobeck fuel controller
-big horn originals/mega mayhems depending on the ride
shane-o is offline
post #4 of 4 (permalink) Old 09-16-2019, 05:47 PM
stave7119's Avatar
When it hydro locked it could have broken a piston or bent a rod. Was there water in a cylinder? I am afraid you did some damage inside. If it isn't running right, its time to pull it apart.
2018 Kawasaki KLR650
SOLD 2004 Sportsman 600 Twin
stave7119 is offline
