2010 Polaris 500 H.O wont accelerate - Polaris ATV Forum
post #1 of 22 (permalink) Old 09-13-2019, 04:45 PM Thread Starter
Karcillo12's Avatar
I recently bought a used atv from a guy and it seemed to run alright at the time. The atv only has 1100 miles at the moment. My issue is the bike starts and idles fantastic! It runs perfect right up to 20km/hr or so at roughly 4500rpm..but as soon as you push the throttle any more it bogs and wont accelerate any further. The throttle is only maybe 1/4 way open to get to that speed. Now if you slowly feather the throttle it will get to 6500rpm and get passed the initial 4500rpm but its not anywhere near responsive enough. The thing is when its cold it was reving up fine perfectly..no bogging or anything..issue only seems to come up when the machine has been running. Ive changed air filter and sock, oil and filter, and fuel filter. Im leaning on a carb issue but was just wondering if anyone else had a similar issue with a fix. Thanks a bunch in advance!!
Karcillo12 is offline
post #2 of 22 (permalink) Old 09-13-2019, 05:00 PM
bp405's Avatar
Sounds like the belt is slipping. Does it rev right up in P or N??
2011 Sportsman® 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsman® 570-T
2019 Aluma® A8818
2020 Outlander® 1000R XXC
bp405 is online now
post #3 of 22 (permalink) Old 09-13-2019, 05:15 PM Thread Starter
Karcillo12's Avatar
It did off the start when i started it cold. The idle was set way too high at the 4500rpm mark and i had it reving up full throttle in neutral. Now that its been running for a while it wont rev up at all passed that 4500rpm in P or N. Should eliminate the belt slippage i believe?
post #4 of 22 (permalink) Old 09-13-2019, 05:27 PM
bp405's Avatar
Ok so that sounds like a carb issue then .
QSC clutch kit
added 7 zerks
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
2019 Aluma® A8818
bp405 is online now
post #5 of 22 (permalink) Old 09-13-2019, 05:39 PM Thread Starter
Karcillo12's Avatar
Ok so that sounds like a carb issue then [IMG class=inlineimg]https://www.polarisatvforums.com/forums/images/smilies/undwech.gif[/IMG].
Thinking its a plugged high speed jet? Improper float setting? Needle worn? Seat o ring worn?
post #6 of 22 (permalink) Old 09-14-2019, 07:25 AM
Clean the carb - it runs fine when cold because the enrichener is probably still open
latebird is offline
post #7 of 22 (permalink) Old 09-14-2019, 08:33 AM Thread Starter
Karcillo12's Avatar
Ok ill have to do that tonight! Trying to figure out all probable causes before i start diving in.
My battery is only showing 11.5 Volts...could that be a contribution or the issue?
post #8 of 22 (permalink) Old 09-14-2019, 08:51 AM
No, but at 11.5 volts its about 1/2 discharged and needs a good, long, slow charge at no more than 2 amps. Even lower would be better. Use a good automatic charger if available.
polman500 is offline
post #9 of 22 (permalink) Old 09-14-2019, 09:43 AM Thread Starter
Karcillo12's Avatar
Now if the choke cable adjustment right at the carb is screwed all the way in is that it? Choke is all the way open and now shutting?
post #10 of 22 (permalink) Old 09-14-2019, 10:36 AM
Based on the pic, the enrichener will be closed when the holder is screwed into the carb body. You might operate the enrichener to ensure the cable and plunger move freely.
Now check to ensure the carb holder is not cracked and leaking vacuum - if the holder is in good condition, proceed with the carb cleaning
latebird is offline
