2007 Polaris 800 with starting issues - Polaris ATV Forum
post #1 of 10 (permalink) Old 12-14-2009, 11:06 AM Thread Starter
BigO's Avatar
I have a 2007 Polaris 800 with starting issues. Once you turn the key, you hear the fuel pump clicking but the engine will not start, after a few minutes of playing with the throttle it back fires, sounds like there’s, and explosion then it finally starts. After letting it sit for about an hour or so, it will not start again. Checked codes and there are none, checked fuel pressure and it has the recommended 40 PSI. Does anyone have any ideas that can help me? Thanks for your time.
BigO is offline
post #2 of 10 (permalink) Old 12-14-2009, 11:38 AM
Bruce! is offline
post #3 of 10 (permalink) Old 12-14-2009, 07:48 PM
4play's Avatar
make sure the throttle is adjusted right. you want just a tiney bit of play in it.
4play is offline
post #4 of 10 (permalink) Old 12-15-2009, 09:15 AM Thread Starter
BigO's Avatar
I checked the throttle and is adjusted right, it only has a little bit of play in it.
BigO is offline
post #5 of 10 (permalink) Old 12-15-2009, 02:04 PM
this is EFI right?
blueline15 is offline
post #6 of 10 (permalink) Old 12-15-2009, 02:10 PM Thread Starter
BigO's Avatar
Yes it's EFI.
BigO is offline
post #7 of 10 (permalink) Old 12-15-2009, 02:55 PM
4play's Avatar
when your cranking it and it will not start take that fuel valve cap off of the fuel rail and see if the rail has pressure. if it dont, more than likely that stupid lil return valve on the fuel pump is probably going. only option would be to buy a ney gas tank/ pump from polaris for around 500 bucks.
4play is offline
post #8 of 10 (permalink) Old 12-28-2009, 07:13 AM Thread Starter
BigO's Avatar
Checked the fuel rail next to the injectors and it has 40 PSI. Still does not run.
BigO is offline
post #9 of 10 (permalink) Old 12-29-2009, 01:28 AM
loosque09's Avatar
I live in TN just over the North Georgia border. THere is no one close by here that can help me. I have been looking in Gainsville.
loosque09 is offline
post #10 of 10 (permalink) Old 01-11-2010, 12:54 PM Thread Starter
BigO's Avatar
Ok, I found the problem it was code #21. Had to replace the cam sensor, and it started right up. Thanks for all your help.
BigO is offline
2007 Polaris Sportsman 800 efi hhecht0788 ATV Repair and Maintenance 6 04-29-2018 07:17 AM
2011 Polaris Sportsman 800 EFI ENGINE HArdwater08 Polaris Sportsman 1 09-14-2017 10:13 AM
Importing Polaris 2007 800 into US from Canada DJKing ATV General Discussion 1 03-29-2017 04:56 AM
2007 Polaris starting issues Zanester ATV General Discussion 0 09-09-2016 08:23 AM
