What weight is hub oil? - Page 4 - Polaris ATV Forum
post #31 of 33 (permalink) Old 01-28-2012, 07:46 AM Thread Starter
carralo1's Avatar
Is it common that just the front right rubs? I'm gonna flip tre and add washers. How do I re align after? Thanks
carralo1 is offline
post #32 of 33 (permalink) Old 01-28-2012, 11:28 AM Thread Starter
carralo1's Avatar
Flipped tie rod end. Added washers. Steering is lose now what's the best way to adjust. And wheels wobble a little. How should I fix
carralo1 is offline
post #33 of 33 (permalink) Old 01-28-2012, 09:45 PM
lost cause's Avatar
Do not add washers on the wheel studs. This is not a good alternative to wheel spacers. Get some wheel spacers. As for the steering wobble, check and ensure your tie rod ends are tight since you did the flip.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N AIR FILTER
POLARIS 3500 WINCH
POLARIS OEM BELT
STOCK EXHAUST
lost cause is offline
Tire Weight vs. Power jac42779 Polaris Sportsman 8 01-18-2012 05:48 PM
Tire weight ? Amccoy ATV Wheels & Tires 30 10-05-2011 09:48 AM
Tire Weight? duffer Polaris XP 3 04-08-2011 12:42 PM
sportsman 850 xp weight. laan123 Polaris Sportsman 1 01-24-2011 04:58 AM
What weight of oil? threecows ATV Repair and Maintenance 5 11-10-2010 09:12 PM
