Grinds In Reverse Really Bad?? - Page 7 - Polaris ATV Forum
post #61 of 67 (permalink) Old 02-26-2012, 06:38 PM
hemp22's Avatar
Make sure the tranny is in netural, the bearings just pop off (take pictures it will help)
Watch this youtube video it is helpful
hemp22 is offline
post #62 of 67 (permalink) Old 02-26-2012, 06:44 PM Thread Starter
carralo1's Avatar
I can't get the bearings to pop off.. That's really my only issue. Once I get those off I'll be fine
carralo1 is offline
post #63 of 67 (permalink) Old 02-27-2012, 03:37 PM Thread Starter
carralo1's Avatar
See, theyre bearings come right off... mine wont. Once I can get that off Ill be allset
carralo1 is offline
post #64 of 67 (permalink) Old 02-27-2012, 03:49 PM
jac42779's Avatar
I used a 3 jaw puller to remove all my bearings. Since I had it all apart, I replaced all the bearings that any bearing house will have for a little cheaper. If you do replace them I would not use the cheap china bearings if you can help it. I found good ol American Made bearings at my local John Deere dealer.
A tip for when you go back to install the bearings is to use a heat gun and heat the bearings up a little before installing. You can get the heat gun at Lowes or etc. they will be in the paint section.
jac42779 is offline
post #65 of 67 (permalink) Old 02-28-2012, 07:23 AM
hemp22's Avatar
I just used 2 screw drivers to pop them up, but if you have a 3 jaw that will work to.
Be careful if you decide to heat the bearings though they can get damaged real easy (mine just slid on with a little lube)
hemp22 is offline
post #66 of 67 (permalink) Old 02-28-2012, 10:10 AM Thread Starter
carralo1's Avatar
Ok got bearing off the top left shaft inside transmission then I removed low gear shifting fork. Do I need to remove the bearing and large gear on bottom of transmission? Do I need to remove high and reverse shifting fork? And how do I get low gear fork back in, It seems impossible to put a flathead in there to push that pin back...
carralo1 is offline
post #67 of 67 (permalink) Old 05-15-2013, 07:09 PM
dholland17's Avatar
carral01...How did you eventually get your transmission out? I'm having the same problem. Did the 2" swingarm bolt need to come out?
dholland17 is offline
2010 850 ADC grinds on decel? madmathew ATV Repair and Maintenance 0 07-26-2011 06:09 PM
99 500 4x4 grinds bad when shifting nick34 Polaris Sportsman 5 06-15-2011 05:50 PM
New axle in 02 scrambler grinds when put into gear scrambler5004x4 Polaris Scrambler 8 06-15-2011 04:58 AM
88 trail boss grinds going into gear & vacuum question brian5z ATV Repair and Maintenance 4 11-26-2010 04:54 PM
88 trail boss grinds going into gear = brian5z ATV Repair and Maintenance 0 11-24-2010 01:31 PM
