Magnum 325 2x4 drive shaft removal (pics) - Polaris ATV Forum
post #1 of 13 (permalink) Old 05-22-2012, 08:28 PM Thread Starter
Ricky's Avatar
(Resolved!) Magnum 325 2x4 Swing arm removal (pics)
Hey fellas, great forum ya'll have here and I hope I can take advantage of some of the minds on the forum.
I am in the process of replacing the swing arm bearings etc. on a 2002 2x4 Magnum 325. I have run across a problem that has stopped me dead in my tracks. I have removed the right and left pivot bolts from the swing arm, but I can't get to the bearings because I can't raise the arm high enough to get to them. I can't raise the front of the swing arm because the drive shaft runs through it.
How the heck do I disconnect the drive shaft so I can raise the swing arm up? Looks like there's a roll pin on the spline portion, but I'm worried that that's the hard way of doing it. There's also the U-joint? I think that's what it's called. Is it easy to separate those? If so, how? I have attached some photos because sometimes it's hard for me to describe things. A picture and all that, ya know.
Any ideas and advice would be greatly appreciated!
Thanks!
ID:	7404   Click image for larger version
ID:	7405   Click image for larger version
Ricky is offline
post #2 of 13 (permalink) Old 05-23-2012, 07:14 AM
Corey850XP's Avatar
Hey,
All you have to do is remove the rearend. Un bolt the shock and brake caliper,
then take the 7 bolts out, and it will slide back and out. Then pull the swingarm
and install new bushings.
Corey850XP is offline
post #3 of 13 (permalink) Old 05-23-2012, 09:31 AM Thread Starter
Ricky's Avatar
Originally Posted by Corey850XP View Post
Hey,
Thanks for the reply, Corey!
I'm new to this, so here's another question. I understand how to remove the caliper and shock, but the 7 bolts? Are these holding the drive shaft to the rear end? Could you give me a general location to look for the bolts?
Thanks again!
Ricky is offline
post #4 of 13 (permalink) Old 05-23-2012, 09:34 AM
Corey850XP's Avatar
Your welcome Ricky.
There are 3 on the left side through the swingarm, back by the axle. The other 4
are on the right side that go into the rearend housing.
post #5 of 13 (permalink) Old 05-23-2012, 10:08 AM Thread Starter
Ricky's Avatar
Your welcome Ricky.
I'll definitely give this a try and report back.
Thanks again, Corey!
Ricky is offline
post #6 of 13 (permalink) Old 05-23-2012, 11:24 AM
Corey850XP's Avatar
Let me know how you make out.
post #7 of 13 (permalink) Old 05-23-2012, 02:21 PM Thread Starter
Ricky's Avatar
Worked like a charm! You were exactly right and I truly appreciate it, Corey.
I'm going to post some pictures of what you had me do just in case someone's searching for this same answer.
ID:	7407   Click image for larger version
ID:	7408   Click image for larger version
ID:	7409   Click image for larger version
Ricky is offline
post #8 of 13 (permalink) Old 05-23-2012, 02:30 PM
Corey850XP's Avatar
Sweet!!!!!!!! Let me know if you need anything else.
post #9 of 13 (permalink) Old 05-23-2012, 02:35 PM Thread Starter
Ricky's Avatar
Oh, I will for sure!
Could a moderator change the thread title to "(Resolved!) Magnum 325 2x4 Swing arm removal (pics)"?? Maybe?
Ricky is offline
post #10 of 13 (permalink) Old 07-21-2012, 09:45 AM
dugger's Avatar
Ricky and Cory, thanks for posting these pictures and having this discussion, I need to do the same thing to my 235 and the pic's were extremly helpful. I own both of you a steak dinner!!!
dugger is offline
rear drive shaft removal 304ronnie ATV Repair and Maintenance 8 08-26-2011 11:18 AM
Front drive shaft removal jleo1 ATV Repair and Maintenance 5 05-09-2011 06:36 PM
Front Drive Shaft Removal maverick11 ATV Repair and Maintenance 1 04-21-2011 09:59 AM
2002 Sportsman 700 rear drive shaft removal pbm1957 ATV Repair and Maintenance 5 01-20-2011 08:49 AM
HELP, rear drive shaft removal. rust Polaris Sportsman 2 08-16-2009 03:58 PM
