95 Magnum 425 issues - Page 2 - Polaris ATV Forum
post #11 of 15 (permalink) Old 03-09-2010, 02:18 PM Thread Starter
Spitfire79's Avatar
Thanks. Got an idea of where to start now
Spitfire79 is offline
post #12 of 15 (permalink) Old 03-09-2010, 03:47 PM
atvjunkie821's Avatar
Double check the slide diaphragm in the carb the slightest hole or tear will cause bogging and slow revs. I had this happen to mine during a rebuild.
95 Magnum 425 4x4 , 518HO carb & air box, 12inch rear wheel conversion.
02 Magnum 500 RMK
atvjunkie821 is offline
post #13 of 15 (permalink) Old 03-10-2010, 07:34 AM Thread Starter
Spitfire79's Avatar
Thanks. I'm going to start into it this weekend. Probably will end up going further than I anticipate.
What about tires. Its going to need this year, what does everyone like. I dont really have trails. Its field, bush, mud
post #14 of 15 (permalink) Old 03-10-2011, 02:04 AM
Christina's Avatar
I like the ground clearance, it handles quite well for a larger machine,the awd button makes switching from 2wd to 4wd a breeze, all in all its one great machine..
Christina is offline
post #15 of 15 (permalink) Old 03-24-2011, 09:25 AM Thread Starter
Spitfire79's Avatar
Well guys, turns out it was a coil on the stator. Dealer finally tracked it down. They were at a loss as well.
Thanks for all your help
Jeff
95 xplorer transmission case Posdeer ATV General Discussion 3 01-16-2018 04:21 AM
1998 Magnum 425 fuel issues? bldmtnrider Polaris Magnum 6 08-09-2017 07:40 AM
98 425 magnum 4wd issues. Front left won't turn. Fordpickupjaybird Polaris Magnum 0 11-29-2015 01:48 PM
