2010 polaris sportsman 500 ( NO REVERSE BUT ALL OTHER GEARS WORK FINE?) - Polaris ATV Forum
post #1 of 7 (permalink) Old 11-26-2012, 03:00 PM Thread Starter
kurtis169's Avatar
2010 polaris sportsman 500 ho no reverse gear (like its in park or neutral)
so the other day i was pulling a buddies bike out in reverse and i lost my reverse gear. all other gears and everything else on the atv works perfectally. im assuming that pulling people out in reverse may not be the best idea ,
but i would like to get the bike fixed up as soon as possible any suggestions on what may be wrong would be greatly appreciated. im assuming it would be the silent chain in the transmission, thanks !
kurtis169 is offline
post #2 of 7 (permalink) Old 11-26-2012, 03:10 PM
InRBigness's Avatar
Check to make sure the bell crank on the shifter rod is not cracked. If it is it will not allow it to go into reverse.
08 Sportsman 500HO
01 500HO Plow Machine
InRBigness is offline
post #3 of 7 (permalink) Old 11-26-2012, 03:24 PM
Bruce! is offline
post #4 of 7 (permalink) Old 11-26-2012, 04:10 PM Thread Starter
kurtis169's Avatar
thanks for the help greatly appreciated ! although the belcrank does not appear to be cracked ! any other suggestions ?
post #5 of 7 (permalink) Old 11-27-2012, 03:05 AM
Corey850XP's Avatar
sounds like the silent chain inside the trans. it only affects reverse gear, common problem, and not too bad to repair.
Corey850XP is offline
post #6 of 7 (permalink) Old 11-27-2012, 03:26 AM
lost cause's Avatar
Sounds like the chain. I have never had one go out, but it seems to be an issue. Especially on the new 900 rzr. Anyway, try to always pull in forward low gear if you can. Pulling in reverse puts a lot of stress on the parts. I destroyed my front differential that way.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N AIR FILTER
POLARIS 3500 WINCH
POLARIS OEM BELT
STOCK EXHAUST
lost cause is offline
post #7 of 7 (permalink) Old 11-27-2012, 05:32 AM Thread Starter
kurtis169's Avatar
alright thanks for the help guys, looks like im gona be taking off the trans...
01 Sportsman 500 - Idles fine but when gears engaged it stalls sconcologyrn Polaris Sportsman 10 07-03-2019 05:14 AM
How to use clutch and gears on a 450 outlaw 2010 cmcom Polaris ATV How-Tos 5 03-21-2012 05:39 PM
2010 sportsman 500 help with gears DLiles36 Polaris Sportsman 5 02-03-2011 11:36 AM
2010 Sportsman 500 AWD in reverse? Green Demon ATV Repair and Maintenance 3 12-27-2010 12:16 PM
AWD doesn't work in reverse msbrockman Polaris Sportsman 1 05-01-2010 01:33 PM
