*front propshaft removal - Polaris ATV Forum
post #1 of 4 (permalink) Old 06-08-2013, 12:56 PM Thread Starter
DirtyFikes's Avatar
I am trying pull my front prop shaft off and its stuck. I pulled the frontpin out, took a wire brush and cleaned off the splines, wd40'd them and packed it full of grease. It will only slide 1/4" till it stops. Anyone else had this problem? If so how can I fix it?
DirtyFikes is offline
post #2 of 4 (permalink) Old 06-08-2013, 01:22 PM
creekman's Avatar
yep had that problem before. it took a pickle fork and hammer to get it off the transmission shaft
creekman is offline
post #3 of 4 (permalink) Old 06-08-2013, 08:12 PM
lost cause's Avatar
Just keep greasing it and working it back and forth. If that still doesn't work you could unbolt the front diff and then just pull it off.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N AIR FILTER
POLARIS 3500 WINCH
POLARIS OEM BELT
STOCK EXHAUST
lost cause is offline
post #4 of 4 (permalink) Old 06-09-2013, 05:30 AM Thread Starter
DirtyFikes's Avatar
I have to pull the front differential anyway. That's why I'm taking the shaft out. Is there enough room for it to pull off?
magnum front propshaft removal rubio07 ATV Repair and Maintenance 4 01-01-2015 07:54 AM
Sportsman Propshaft Grease? 600RacerX Polaris Sportsman 6 07-31-2012 07:19 PM
Aftermarket Greasable Propshaft U-joints Riverjet ATV Repair and Maintenance 6 05-02-2012 04:39 PM
turner propshaft racer37l ATV Performance Modifications 0 10-19-2010 03:31 PM
2005 Front propshaft u-joint replacement?? christpuncher Polaris Sportsman 11 06-29-2010 07:11 AM
