13 Sportsman 850 XP HO rough idle - Polaris ATV Forum
post #1 of 66 (permalink) Old 01-18-2014, 09:29 AM Thread Starter
Ultra's Avatar
Bought this 2013 and it ran great until I go it home of course. I did buy it used so problem is now mine unfortunately. Rough idles and when I try and ride it the thing just falls on its face. I thought it was the tps. Got new tps in yesterday and went to install it. I have a tps inline adjuster that I bought that helps you adjust the position correctly. I could never get the new or the old tps to the correct voltage that it needs. So I am guess there is something else wrong before the tps causing the tps to not get the correct reading. I have put new plugs in and difference. I have taken IAC off cleaned it and actually swapped it with another one and no difference. I have taken tmap off and cleaned and reinstalled it, no difference. What am I missing here? Running very rich, bad hesitation. Oh and I have adjusted the throttle cable making no difference. I get a 520 194 7 code, Throttle Release Signal - Throttle Stuck is the description. I have a 09 with exact same throttle body. I swapped the throttle bodies and exact same issue, to differences. Any help would be appreciated. TIA, Ultra
Uploaded video of what it is doing to youtube.
2013 Sportsman 850 XP HO Green
2011 Sportsman 90
2009 Sportsman 850 XP EPS Orange
2008 Sportsman 800 HO Red
2008 Sportsman 800 RZR
2003 Sportsman 700 Twin
Ultra is offline
post #2 of 66 (permalink) Old 01-18-2014, 10:22 AM
ChickenHawk's Avatar
Did you replace the Champion plugs with NGK? A lot of guys run a hotter NGK plug to alleviate fouling(if that is indeed your problem). Do you let your machine idle for extended periods of time?
ChickenHawk is offline
post #3 of 66 (permalink) Old 01-18-2014, 10:26 AM Thread Starter
Ultra's Avatar
Dealer installed new plugs in front of me before I purchased. I don't even have 1 mile on this unit since I purchased it used. I did pick up some NGK Iridium plugs yesterday from Napa but haven't put them in yet as I didn't think they would make a difference since dealer had installed the new plugs and less than 30 mins on them.
2011 Sportsman 90
Ultra is offline
post #4 of 66 (permalink) Old 01-18-2014, 11:37 AM
4xfun's Avatar
I couldn't tell in vid but the contacts for the etc should not be touching at idle or better to say when not touching throttle they should have slight gap. If they were or are touching you can foul plugs quickly cause it triggers stuck throttle and stops spark.
Sent from my iPad using Tapatalk
13 Sportsman 850 XP LE Stealth Black
Items from Thor www.theatvsuperstore.com
14" STI HD3 wheels
27x9x14 and 27x11x14 Grim Reaper tires
Fender Flares
Items from Ridinagain www.rvsperformance.com
QSC clutch kit
Denali 60" Plow
Synthetic winch rope and hawse
XP Frame brace from Rick Cecco
Polaris Front and Rear bumpers
NGK Irridums
Amsoil fluids
^This thing is Sweeet^
05 Sportsman 800 EFI (Sold)
04 Sportsman 700 carb (Sold)
4xfun is offline
post #5 of 66 (permalink) Old 01-18-2014, 11:39 AM Thread Starter
Ultra's Avatar
Yes contact for both throttle bodies have contacts touching while at idle. Anyone have a video on how to correct adjust cable then?
Sent from my SCH-I545 using Tapatalk
2011 Sportsman 90
Ultra is offline
post #6 of 66 (permalink) Old 01-18-2014, 11:47 AM
4xfun's Avatar
I should preface this with what I run is an 800 sporty. My manual talks about using the adjuster in the cable and making sure there is about an eight inch between contacts when not touching throtle.
14" STI HD3 wheels
Fender Flares
QSC clutch kit
Denali 60" Plow
NGK Irridums
Amsoil fluids
4xfun is offline
post #7 of 66 (permalink) Old 01-18-2014, 11:50 AM
4xfun's Avatar
Maybe you could search etc adjustment for Xp and find something
14" STI HD3 wheels
Fender Flares
QSC clutch kit
Denali 60" Plow
NGK Irridums
Amsoil fluids
4xfun is offline
post #8 of 66 (permalink) Old 01-18-2014, 11:55 AM Thread Starter
Ultra's Avatar
I'll read service manual section again. Thought it said 1/8 in between the stops. Think the contacts were closed though.
2011 Sportsman 90
Ultra is offline
post #9 of 66 (permalink) Old 01-18-2014, 11:59 AM
4xfun's Avatar
If they are closed it cuts out spark and plugs can foul rapidly. So get that adjusted and if not better than pull plugs and change.
sent from my S4
14" STI HD3 wheels
Fender Flares
QSC clutch kit
Denali 60" Plow
NGK Irridums
Amsoil fluids
4xfun is offline
post #10 of 66 (permalink) Old 01-18-2014, 12:00 PM
4xfun's Avatar
There should be an adjuster in the throttle cable to make that adjustment.
sent from my S4
14" STI HD3 wheels
Fender Flares
QSC clutch kit
Denali 60" Plow
NGK Irridums
Amsoil fluids
4xfun is offline
Sportsman 800 Running ROUGH/Won't Idle Dempsey7 ATV Repair and Maintenance 4 01-28-2018 02:09 PM
2007 700 sportsman rough idle backfire polaris07700 ATV Repair and Maintenance 18 01-28-2016 03:00 PM
05 Sportsman 700 EFI, rough idle bhi3202 Polaris Sportsman 5 08-19-2012 11:14 PM
2008 ranger 500efi rough idle and won't idle down after its warm? Duramax68 ATV Repair and Maintenance 2 05-19-2012 02:54 PM
05 500 Sportsman Hard Start When Warm and Rough Idle theheisk Polaris Sportsman 4 04-05-2011 08:10 AM
