2005 sportsman 700 efi problem - Polaris ATV Forum
post #1 of 27 (permalink) Old 03-12-2014, 02:24 PM Thread Starter
vroompsh's Avatar
Hi everyone,
I have a 2005 Polaris Sporstman 700 EFI.
Issue:
- Lack of power
- engine revs slowly until it finally reaches redline.
- when in any gear, it's gutless
Here's what's been done to my quad to try to fix the issue:
- new spark plugs (old ones were black and one was a little wet)
- new spark plug wires
- checked for codes
- checked voltage on yellow wire on tps sensor (.710 volts with key on)
- checked wiring to tbap (one wire was frayed a little)
HAVE REPLACED TBAP WIRING WITH OTB's WIRING HARNESS AND THERE'S NO DIFFERENCE SO FAR.
This issue seems to have started after the quad was ridden in heavy rain. This was at the end of last summer. Haven't had time to fix it till now.
Any help would be greatly appreciated.
vroompsh is offline
post #2 of 27 (permalink) Old 03-12-2014, 03:41 PM
Sjjr613's Avatar
Have u checked the air filter and by the sounds of the plugs your running rich. Maybe you got water in the gas. Im not to familiar with efi so hopefully someone else will chime in to futher assist u.
Sent from my SGH-I337M using Tapatalk
2011 sportsman 500
28" maxxis zillas tires
M9 patriot rims
Polaris hand guards
Front and back bumpers
Glacier plow
3 light mod
QSC clutch kit
exhaust mod
uni filter
Sjjr613 is offline
post #3 of 27 (permalink) Old 03-12-2014, 03:45 PM Thread Starter
vroompsh's Avatar
I've checked my K&N filter. I've even ran it quickly without a filter. Same issue. I've cleaned out the tank and put in new fuel. I've also installed a new airtex fuel pump since I thought that was the issue at first.
vroompsh is offline
post #4 of 27 (permalink) Old 03-12-2014, 06:00 PM Thread Starter
vroompsh's Avatar
Does anyone know what voltage is supposed to come out of the wires going to the tbap? My harness has a pink, pink with white stripe, purple, and orange wires. I'd like to rule out any broken wires. When I tested these wires for voltage, only two of the wires registered any voltage. The other two had none at all. I'm just wondering if those two wires are broken, or if those two wires are supposed to have 0 volts. This testing was done with the key in the on position.
vroompsh is offline
post #5 of 27 (permalink) Old 03-13-2014, 04:47 PM Thread Starter
vroompsh's Avatar
I figured something out today. I unplugged the coolant sensor and the bike started running almost perfectly. Going to test the sensor tomorrow.
vroompsh is offline
post #6 of 27 (permalink) Old 03-14-2014, 03:13 PM Thread Starter
vroompsh's Avatar
Replaced the coolant thermistor and made no difference. Still runs perfectly if I disconnect the plug to this sensor. Does anyone have any ideas?
vroompsh is offline
post #7 of 27 (permalink) Old 07-26-2014, 05:42 PM Thread Starter
vroompsh's Avatar
Thought I'd bump this thread since I still haven't figured out the issue yet...
vroompsh is offline
post #8 of 27 (permalink) Old 07-26-2014, 07:20 PM
71Gibby's Avatar
Is there a possibility there could be an air lock around the sensor location? I have read somewhere that you need to bring the front end of the wheeler up higher than the rear to burp air through the cooling system.
I feel your pain as I have an issue I need to resolve and have not had any responses either.
Good Luck!!
71Gibby is offline
post #9 of 27 (permalink) Old 07-26-2014, 07:23 PM Thread Starter
vroompsh's Avatar
Good Luck!!
Wouldn't that just cause the machine to overheat?
vroompsh is offline
post #10 of 27 (permalink) Old 07-30-2014, 07:55 AM Thread Starter
vroompsh's Avatar
bump
10char
vroompsh is offline
2005 Sportsman 800 AWD Coil Problem R3APeR ATV Repair and Maintenance 7 08-01-2015 04:09 PM
2005 Sportsman 800 Starting Problem R3APeR ATV Repair and Maintenance 3 04-22-2013 02:40 AM
2005 Sportsman 700 Electrical Problem scodemike ATV Repair and Maintenance 4 10-30-2012 04:58 PM
electrical problem 2005 sportsman help.... srt2 ATV New Members 2 11-28-2010 05:52 PM
2005 Sportsman 500 problem. Dan ATV Repair and Maintenance 4 06-17-2009 08:15 PM
