02 700 running issue - Page 2 - Polaris ATV Forum
post #11 of 18 (permalink) Old 07-06-2014, 10:51 AM
Treacherous's Avatar
Originally Posted by KSZRT View Post
Originally Posted by Xploder View Post
Has that shitty ducati ignition, you sure it aint running on 1 cyl?
I was going to ask the same. I got rid of it on my 03 and what a difference!!!
Did you go with that cheaper aftermarket kit?
Polaris Sportsman 600 700 2002-2006 Stator and CDI Ignition Upgrade (CDI + External Coil Kit)
• '13 Polaris 550 XP EPS (1K- miles/90 hours) (4/11/2013 build/Polaristar until 9/2018)(Road legal)
-Polaris Deluxe Front (2876595) & Rear (2876597) Brushguards
-Thor's best ATV mirrors
-Polaris Steel Front & Rear Rack Extenders
-Ricochet full 8 piece kit (black anodized)
-Cecco frame brace
-Silent Rider (ATV Silencer)
-WARN ProVantage 3500
-KFI Winch mount
-Polaris OEM grip & thumb heaters
-Polaris Front lock & ride box
-Thor's 3 Way ATV Hitch 1 1/4" Box type
• '04.5 Polaris 700 SP EFI (3268 miles/302 hours) - Gen VI chassis (Original Owner)(Road legal)
• '85 Honda TRX 250
Washington Off Highway Vehicle Alliance (WOHVA)
Treacherous is offline
post #12 of 18 (permalink) Old 07-06-2014, 12:48 PM Thread Starter
RVS Performance's Avatar
Yes it still has the original Ducatti ignition. It runs on both cylinders, just seems like the timing advance is gone. Seen that on a bunch of vintage race sleds over the years. It's getting a new ignition next week.
RVS Performance is offline
post #13 of 18 (permalink) Old 07-06-2014, 01:56 PM
Banned
aknawful's Avatar
crank didn't go out of phase (twist)? Those old twins had crank issues.
aknawful is offline
post #14 of 18 (permalink) Old 07-07-2014, 02:44 AM
KSZRT's Avatar
No I went with the OEM replacement
KSZRT is offline
post #15 of 18 (permalink) Old 01-22-2015, 06:35 PM
rwchugger's Avatar
Mine had similar issues, 700 2004, non ducati, it turned out to be a plug wire rubbing and grounding to the frame, only while moving, not at idle, and it would miss around 40 mph and get through it. Followed the wires and got lucky and found a wear mark, taped it, ran fine. They have since been replaced without re-occurring issue.
rwchugger is offline
post #16 of 18 (permalink) Old 01-23-2015, 04:25 AM
boomer632's Avatar
Check the rubber intake manifold for cracks. Had mine do same thing then found the rubber intake cracked and was causing a lean condition anywhere past 1/4 throttle
boomer632 is offline
post #17 of 18 (permalink) Old 01-23-2015, 04:27 AM
rwchugger's Avatar
Forgot about that as well, had that twice.
post #18 of 18 (permalink) Old 01-23-2015, 05:17 AM Thread Starter
Should have updated this. Turned out to be mainly the cam and all the lifters were shot. And the ignition advance was gone as well.
07 Sportsman 500HO EFI X2 running issue skunk ATV Repair and Maintenance 3 11-15-2013 09:07 PM
trailboss running issue kmhunter Polaris Trail Boss 2 05-28-2013 08:23 AM
2000 Polaris Scrambler 400 running issue please help. coljb614 Polaris Scrambler 1 08-06-2012 06:26 AM
2005 700 sportsman efi running issue drfong ATV Repair and Maintenance 5 12-24-2010 11:01 AM
1996 Sportsman 500 Running Issue volfan Polaris Sportsman 1 10-12-2009 05:47 PM
