2000 scrambler 500 starting issue/starter?? - Polaris ATV Forum
post #1 of 3 (permalink) Old 08-13-2014, 07:10 AM Thread Starter
2wheeler's Avatar
ok shes been running so I know it runs.
went to start the other day she starts....waited another 3 days or so now when I got to start I just hear solonoid click. I think battery low...I even have hooked to my trucks battery and just click. I associate this usually with not enough power to dick the solonoid but Im wonder if the ring gear stuck on flywheel..I dont this so cuz every subsequent start sequence it clicks again.
Thinking of opening up and turning flywheel to another spot incase a "flat spot in the system? any other thoughts...new to atvs.....thanks
she spun many other times.
Thanks all
2wheeler is offline
post #2 of 3 (permalink) Old 08-14-2014, 03:55 AM
Have you charged/checked the battery? Use your jumper cables to put power directly to the starter. If it cranks your starter is good. Sounds to me like a bad battery and/or connections. If the starter checks out, hold the start button down and cross out the solenoid terminals with a screw driver to check the solenoid. If it cranks that way, the solenoid is bad. Again of course, that ONLY works if the battery is charged and the connections are good. Also, rust under the solenoid mounting bolts can cause a loss of ground too that can prevent it from working.
polman500 is offline
post #3 of 3 (permalink) Old 08-14-2014, 04:12 AM Thread Starter
2wheeler's Avatar
battery checks out good..too apart and cleaned all connections well.....when I put directly to starter works fine...but then hooked up back the right way and click.
maybe a new Solnoid pc that the battery cables go to????
2wheeler is offline
2000 xplorer 400 starting issue Djhoffman ATV Repair and Maintenance 4 05-24-2014 06:06 AM
03 Sportsman 500 HO, Belt issue and Starter Issue Triple_R_Rabbits Polaris Sportsman 3 07-24-2013 06:59 AM
start issue 2000 polaris scrambler 500 4x4 kpierce12 ATV Repair and Maintenance 9 04-22-2013 08:47 PM
2000 Polaris Scrambler 400 running issue please help. coljb614 ATV Repair and Maintenance 2 08-09-2012 12:33 AM
2000 Polaris Scrambler 400 running issue please help. coljb614 Polaris Scrambler 1 08-06-2012 06:26 AM
