600 sportsman over charging - Polaris ATV Forum
post #1 of 3 (permalink) Old 08-13-2014, 02:06 PM Thread Starter
gmcduffi's Avatar
Just had voltage regulator replaced, it is delivering 17.5 volts to battery, is very hot and stops working, also bike seems to run just a little smoother when I disconnect. THe shop keeps trying stuff but keeps costing more and more and cant figure it out.
ANY SUGGESTIONS
gmcduffi is offline
post #2 of 3 (permalink) Old 08-13-2014, 02:16 PM
al53's Avatar
there are only 2 components in the charging system...the stator and volt reg...have to test the stator to see if it is with in specs....I forget what the Ohm readings are off the leads plugs....if that reads ok then the reg may be defective....the stator gives off AC an the reg converts to DC ,,
the specs are in the shop manual and also the test procedure....
2002 Sportsman 500HO
1987 Suzuki LT250 4x4 The Beast
al53 is offline
post #3 of 3 (permalink) Old 08-13-2014, 09:08 PM
Welcome to the board.
Bruce! is offline
2005 700 carb over charging and not charging bankshot ATV Repair and Maintenance 1 02-23-2014 07:42 PM
05 sportsman not charging 05polaris ATV Repair and Maintenance 2 04-06-2012 03:35 PM
Sportsman 700 not charging 05polaris Polaris Sportsman 0 04-03-2012 11:09 AM
Sportsman over charging Dawdyservices ATV Repair and Maintenance 4 01-21-2012 05:55 PM
07 sportsman 90 Not Charging dirttracker ATV Repair and Maintenance 0 09-07-2010 06:15 AM
