2003 Sportsman 600 4 wheel drive not engaging - Page 2 - Polaris ATV Forum
post #11 of 16 (permalink) Old 03-29-2015, 06:20 AM
kvfd181's Avatar
I also did the diagnosis on the speedo and the AWD says on so i know now at thia point its a mechanical problem so where do i start with the mechanical stuff?
kvfd181 is offline
post #12 of 16 (permalink) Old 03-29-2015, 06:22 AM
kvfd181's Avatar
I did the diagnosis on the speedo and it says AWD on so i know its a mechanical issue so now where do i start with that
kvfd181 is offline
post #13 of 16 (permalink) Old 03-29-2015, 06:22 AM
wncrider's Avatar
I cant get into a diagnostic mode with my speedo for some reason... another reason to think its a bad speedo
wncrider is offline
post #14 of 16 (permalink) Old 03-29-2015, 06:32 AM
kvfd181's Avatar
Mine took a few times to do it. I turned the key off held the button for 15 seconds not 10 and then held it as i started. Then when it started it came up with the battery and wrench symbol and then i hit the overdrive button untill i found the awd selection. Took me atleast 3 to 4 times
kvfd181 is offline
post #15 of 16 (permalink) Old 03-29-2015, 07:36 AM
wncrider's Avatar
yeah mine wont do anything like that..... Wont enter diagnostic mode at all.I also have a check engine light that comes on when its in park only..... I hate electrical issues that Polaris always seems to have
wncrider is offline
post #16 of 16 (permalink) Old 01-10-2017, 09:50 AM
Supraman23's Avatar
My 04 600 cluster all works but the speedo needle don't move. I had the quad on jacks stands and put in gear and at slow speed the rear tires turn and then when i rev more all 4 turn fine. I put it in 4wd and all 4 turn just fine and when i ride it seems okay but no speedo needle moving. Can I clean the wheel sensor maybe? I can't find a new on online anywhere under $65
Supraman23 is offline
Polaris 600 4x4 not engaging 4 wheel drive tuty ATV Repair and Maintenance 3 02-13-2014 05:39 PM
2003 Sportsmen 500 display, speed, 4 wheel drive not work mzim ATV Repair and Maintenance 2 01-21-2013 01:09 PM
problem engaging high gear on sportsman 700 2003 julyjosh ATV Repair and Maintenance 2 10-29-2011 07:54 AM
2003 Magnum 4-wheel drive issues sorrydog Polaris Magnum 3 06-09-2011 11:36 AM
4 wheel drive not engaging when in AWD Trackman ATV Repair and Maintenance 1 11-22-2010 05:09 PM
