"Check Engine" something is wrong, need help. - Page 2 - Polaris ATV Forum
post #11 of 20 (permalink) Old 06-03-2015, 05:47 PM
4oml4's Avatar
It was my dealer who found and fixed my problem . I was able to find some direction by doing a search on google. I just leant my manual out and wont have back for a couple weeks , sorry.
4oml4 is offline
post #12 of 20 (permalink) Old 06-15-2015, 12:13 PM Thread Starter
jason.hopson.927's Avatar
Ok thanks.
Anybody else have any suggestions? Hate the idea of over paying a shop for a simple fix but don't know what else to do at this point.
jason.hopson.927 is offline
post #13 of 20 (permalink) Old 06-15-2015, 12:46 PM
4oml4's Avatar
The throttle sensor is located on the side of the carb, not sure if you can but a manual can be found on line at the library.good luck.
Pat
4oml4 is offline
post #14 of 20 (permalink) Old 06-15-2015, 12:54 PM
4oml4's Avatar
The throttle sensor is located on the side of the carb. I was able to find a manual on line from the library. Good luck.
Pat
4oml4 is offline
post #15 of 20 (permalink) Old 06-15-2015, 02:08 PM Thread Starter
Ok thanks. Mine is fuel injected so it doesn't have a carburetor so to speak. It may still have a throttle sensor wire though so I will check.
post #16 of 20 (permalink) Old 06-15-2015, 02:32 PM
4oml4's Avatar
My 09 Polaris is also fuel injected , guess you call it the throttle body.
Thanks Pat
4oml4 is offline
post #17 of 20 (permalink) Old 06-28-2015, 07:14 AM Thread Starter
Thanks Pat, finally had a chance to look it over and found the throttle sensor you are talking about. No visual damage or broken wires that I can see. I cleaned the connection really well and applied more dielectric grease. Not sure if that made a difference yet on a test drive but it is still showing the same error codes.
My question is will these error codes always show or do they only show when there is a problem? If they always show is there a way to clear them out?
If this cleaning the connectors isn't the problem then I am thinking it maybe a bad tbap sensor. Anyway to check this and or the throttle sensor without purchasing a new one?
Thanks again for the advise!
Jason
post #18 of 20 (permalink) Old 11-06-2015, 07:09 AM Thread Starter
FIXED: So after months of research and the tinkering with all the different possible issues I finally broke down and took it to the dealer for repair. I hated to do this because I like fixing things on my own and I was scared of their sure to be outrageous bill. Found out that the problem was my Crank Position Sensor. This never came up during my searches so im glad i took it to them, the bill wasn't terrible either $260. I mean I could have bought the part for $50-80 and done it myself in about 15 minutes but at least i didn't have to sell the bike to pay for the repair...lol
Back up and running! Thanks for all of your help! Just wanted to share the conclusion with anybody who may google search this later
Sent from my iPad using Tapatalk
post #19 of 20 (permalink) Old 11-06-2015, 01:26 PM
4oml4's Avatar
Hey thanks for the update glade to hear you got it sorted out and the bill wasn't too outrageous.
4oml4 is offline
post #20 of 20 (permalink) Old 06-26-2016, 03:57 PM
canderson's Avatar
Jason, My 09 800 Touring just started doing this same thing recently. Shutting off periodically when idling, also it hesitates when giving full gas. Then it will run perfect no issues for a while with no codes. Then all of a sudden it will stumble and hesitate throw a code 21. Is this what your machine did and was it the crank position sensor itself or was it in the wiring to the sensor. I know these machines have kinda junk wiring, I have already replaced the T-Bap sensor harness. Any help would be greatly appreciated.
2009 Sportsman 800 Touring
GBC Grim Reapers
3 Light Mod, Work Light
Reverse Override, Override Switch
KPI Hook Stopper
Front/Rear Rack Extensions
Rear Touring Rack Bag
Super ATV Front Brushguard
Super ATV Radiator Guard
Kolpin 4 gal Fuel Pac w/custom front rack mount
canderson is offline
05 SP 500 HO flashing "HOT" "Check engine" NCRyders ATV New Members 0 12-17-2014 12:37 PM
325 Trailboss engine "slap". skidmarks ATV Repair and Maintenance 15 08-16-2012 08:11 PM
"Check Engine" eclifford634 ATV Repair and Maintenance 3 01-25-2012 09:52 AM
"Check Engine" eclifford634 Polaris Sportsman 5 01-16-2012 08:48 PM
Engine "whine" from right side normal? NickS ATV Repair and Maintenance 4 01-03-2011 06:15 AM
