08 polaris 800 sportsman no 4x4 - Polaris ATV Forum
post #1 of 4 (permalink) Old 08-18-2010, 10:37 AM Thread Starter
leavitt automotive's Avatar
i have current to electric switch as well as going out of switch,have no wiring schematics,where should i go from here
leavitt automotive is offline
post #2 of 4 (permalink) Old 08-18-2010, 12:28 PM
racer37l's Avatar
Welcome. Since you have power coming from the switch, you need to check the coil in the front differential. I'm not sure if there is a connector close to it or not. Go to Partshark.com, they have downloadable pdf manuals. Good luck
Con
racer37l is offline
post #3 of 4 (permalink) Old 08-18-2010, 09:29 PM
Bruce! is offline
post #4 of 4 (permalink) Old 08-29-2010, 06:11 PM
1dirtypopo's Avatar
You getting a 4wd icon on the speedo? There are two wires coming out of the front diff. Follow the brown one and hook a jumper wire to it and ground the jumper wire to the frame somewhere. There icon might still not work, but the 4wd should. The switch send a signal to the speedo and then to the diff. If the jumper trick works, you prob have a bad speedo. Same thing happened to my 06 700 efi.
700 Sportsman Snorkeled Out 2" lift 28" Mudlites Warn 3000 Tunes, Flashers and a few other goodies to make it go faster and go deeper
1dirtypopo is offline
2009 Polaris Sportsman X2 vs. 2010 Polaris Sportsman 550 X2 str8aro ATV General Discussion 12 04-21-2010 02:30 PM
