Appearance mods - Page 2 - Polaris ATV Forum
post #11 of 18 (permalink) Old 04-22-2013, 06:22 PM Thread Starter
08TouringLE's Avatar
Thorshammer..I'll do that. Since I changed out my rear seat and replaced it with a box for our Lab Presley to ride in, I slightly modified the mounting. I'll try to take a picture tonight or tomorrow evening that I can post with a write up.
08TouringLE is offline
post #12 of 18 (permalink) Old 04-23-2013, 07:53 PM Thread Starter
Thorshammer...here is some info on the flag attachment device I made. The fittings are the cheapest 1/4" airhose fittings I could find at Home Depot. The flag I bought at a Harley Davidson dealer. It's designed to be used on an MC so it can handle ATV wind speed. About $15, I believe. The pole is one of those bicycle orange safety flags available at Wally World. I removed flag and cut the mounting plate off. I had to drill out the male fitting slightly to allow the pole to fit. I then put some JB Weld into it and pushed in the pole and let it harden. This was then threaded into the quick release fitting. The flag, I glued on using a hot glue gun and generous amounts of glue. Originally I had put a bolt through from the underside of the plywood rack extension on my Model T with a nut and washer on the topside. This was to allow me to tighten up the mounting if it loosened. I JB Welded the male fitting onto the bolt. This setup worked great for several years. However, with the modification of my "T" to add Presley's personal seat, I had to rethink the mounting. I bought one of those 10" steel strap "mending" plates, with the holes in them for screws, from ACE. I drilled out a hole to the same size as the threaded end of the male fitting. I attached the mending plate to my new rack extension with several bolts, washers and nuts. I used 2 washers and a brass nut to attach the fitting to the mending plate. The brass was used because the fitting has pipe threads so a regular nut wouldn't work. So far, so good. Does this answer your questions? Gary
post #13 of 18 (permalink) Old 04-24-2013, 07:40 AM
ThorsHammer's Avatar
I like the changes. and will probably go straight to something like that. like I said, I've got a bunch of fittings laying around so thats the easy part.
For those of you interested in doing this. Harbor frieght has the fittings and will probably be less than Home depot. Just an FYI.
ThorsHammer is offline
post #14 of 18 (permalink) Old 04-24-2013, 08:08 AM
MustBeNice's Avatar
Originally Posted by 08TouringLE View Post
As for the highlighting, I used a piece of "automotive" grade self stick vinyl my local Carquest got from one of their suppliers. I believe it was the people they get their pinstripping and paint supplies from. It's very similar to the stuff that was used to put "racing" stripes on vehicles. It's designed for the outdoors. I removed each piece of plastic and thoroughly cleaned it to remove any dirt, residues,etc. I then cut a rectangular piece of the vinyl slightly larger than the letter I was covering. I applied it to the plastic and "burnished" it on using a soft cloth. Finally, I traced around the edge of the letter with a very sharp X-Acto knife. I "burnished" it one more time afterwards. It is time consuming, but the raised lettering made it easier to trace. I only did the letters on the back of Jena's machine as the ones on front are recessed and I'm not sure if I can do it and have good results. I will eventually try. If you decide to do this, make sure you get excess material, 'cause you will make a few mistakes. I also have enough left to redo several letters if they get damaged.
Thanks... may have to pick up some red to do mine (although recessed lettering on the front and bossed on the rear trunk) !!
Matthew "MustBeNice"
MustBeNice is offline
post #15 of 18 (permalink) Old 08-05-2014, 01:29 PM
tlazos81's Avatar
I cant see any pics:-) just triangles with exclamation points. anywhere else we can see the pics?
tlazos81 is offline
post #16 of 18 (permalink) Old 08-05-2014, 09:12 PM
the lovely joys of using web based photo sites. if the site changes at all the pictures don't show up anywhere else.
2017 Sportsman 570 Touring EPS
3500 lbs Polaris winch with Synthetic Rope
Front Utility Rack
ODI Rogue Lockon Grips
25" STI Black Diamond ATRs
Pure Polaris hand guards
4" LED on the pod
Quadworks Stage 1 power kit
  • Dynojet kit
2" rear spring spacers
post #17 of 18 (permalink) Old 08-05-2014, 09:36 PM Thread Starter
Sorry about the photo disconnect....I had problems a while back where if I sent out a link to pics I posted on Picasa, the recipient would be directed to Google+ and asked to sign up for it. When I tried to "break" this link I somehow deleted all of the links I had sent out previously to my online pictures. I probably had almost a thousand I had posted from the past 6 years of riding. I will have to re-upload these pics and post the link here. Give me a day or two to get this done......Gary in Westcliffe...Note that it seems Google has stopped linking Picasa to Google+.
post #18 of 18 (permalink) Old 08-14-2014, 08:11 PM Thread Starter
Finally got to upload the pics of the highlighted names. Note that I also did this to the Polaris name on the rear of my wife's 2012. No pics though.
Mods Under $100 PCA4208 Polaris Sportsman 21 01-08-2013 09:19 PM
What mods for a 400.... Kajunboy89 ATV General Discussion 3 09-01-2012 05:02 PM
mods for my 06 sp 500 efi??? lsxmike ATV Performance Modifications 0 03-15-2010 10:57 AM
