What is a 10mm offset? - Page 2 - Polaris ATV Forum
Sponsored by Discount Tire
post #11 of 23 (permalink) Old 10-24-2018, 06:41 AM Thread Starter
gsxr150's Avatar
Originally Posted by bp405 View Post
Why the lift??? You can get big tires on your ride. I mean if you are going to go through big skeg and snow I get it. But if it's just to be a more capable trail rig you might just want to consider bigger tires. Also if you go lift and tires axles are going to be needed also.
Oh I just figured for the price it would give me some function and a mean look. I do have 27's on the bike now. Dirt Commanders...
gsxr150 is offline
post #12 of 23 (permalink) Old 10-24-2018, 06:42 AM Thread Starter
gsxr150's Avatar
Maybe an extra 2 inches of height is not worth all the hassle. Sounds like the return on investment is not great. Then I won't even need wheels.
gsxr150 is offline
post #13 of 23 (permalink) Old 10-24-2018, 08:05 AM
stave7119's Avatar
No the track width of the 17 and 18 models is no different than earlier ones. From what I have been able to find, all the 850s from 2014 and up use the same wheels. Offset is a measurement of the difference between the center of the wheel and where the wheel mounting flange is at. Zero offset means the mounting flange is dead center in the width of the wheel. Positive offset moves the mounting flange out toward the face of the wheel and negative is back toward the inside/hub side of the wheel. Positive offset wheels have less "dish" than negative offset.
There are several good threads on the forum here if you want to look into it further. They explain it better than I can. Or Google it and get explanations with diagrams.
2018 Kawasaki KLR650
SOLD 2004 Sportsman 600 Twin
stave7119 is online now
post #14 of 23 (permalink) Old 10-24-2018, 08:31 AM
bp405's Avatar
I mean I'm just giving you some info it's all about what puts a smile on your face!!!! With the lift and axles you can go 30"+ tires on there. With the stock set up you can get 28" tires under it.
2011 Sportsman® 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsman® 570-T
2019 Aluma® A8818
bp405 is online now
post #15 of 23 (permalink) Old 10-24-2018, 10:34 AM
I'd have to agree. I was thinking something similar about wheels when I first got my new 1000 but decided after a lot of discussions, research and measurements not to do it. If you just want different looking wheels 5+2 would be the widest I'd go. I ended up putting 27.5 Growlers on the stock wheels and Direction2 flares to keep the mud off and am very pleased with the setup. Saved me a bunch of green I was gonna spend that I probably would have regretted. I'll probably put that green to better use on Elka Stage 3's which, I'm told, are well worth the expense.
polman500 is online now
post #16 of 23 (permalink) Old 10-24-2018, 10:49 AM
FPD218's Avatar
Just remember when you go from 28 to 30 inch tires you only gain 1 inch of additional height the other 1 inch is on the top of the tire!
JUNE 2017 & SEPTEMBER 2018 POLARIS FORUM ATV OF THE MONTH WINNER
2019 Sportsman 850 SP Premium
Removed all Warning Decals
3500# Polaris Winch W/Synthetic Rope
Winch Stopper Cable Line Saver
ATV-GURU.COM Front and Rear Bumpers
2" Receiver in Front Bumper
Kenda K587 HTR Bear Claws 26X9X14 & 26X11X14
Ultimate Series Windshield Fairing, Mid & Low Height Windshield
New Style Polaris Lock & Ride Rear Storage Box
Garmin GPS176C, Ram Mount
Polaris Rear View Mirrors
4" Front Rack Extender
Center Brake/Tail Light LED
Rear LED work lights/strobes
Built on March 27 2019
Purchased New April 13 2019 0.1 Hr .2 Mi
Power Sports Abrams, Wi
SOLD
2006 Sportsman 800 EFI Twin
Purchased new to me on Aug 08 2016 97Hr's 811Mi
Sold Apr 07 2019 231 Hr 3126 Mi
https://www.youtube.com/watch?time_c...&v=k6Nlb_qRoeg
"I am the majority!"
*WEAR A HELMET, I'M LIVING PROOF THEY WORK!
FPD218 is online now
post #17 of 23 (permalink) Old 10-24-2018, 12:33 PM Thread Starter
gsxr150's Avatar
I already have the nice 27's so I'll probably stick with those. Again, I'm thinking about the 2 inch lift and new wheels to add a little width. However I don't want gangster ride width with curb feelers...those 5+2 are very difficult to find!
gsxr150 is offline
post #18 of 23 (permalink) Old 10-30-2018, 03:01 PM Thread Starter
gsxr150's Avatar
Guys, UPDATE! I ordered some 28" tires with some new rims that are "0mm". Man I hope they look OK, or I'm going to get dinged a lot to return them. Why does everyone seem so against 0mm (3.5+3.5) offset? Yeah they will be wider, but isn't it only a couple inches on each side on the 2017 850 SP?
Also, regarding the lift. I saw two guys on youtube with 2017's and the did the little 2-inch highlifter kit and both said they LOVE it and wouldn't change it for a thing.
gsxr150 is offline
post #19 of 23 (permalink) Old 10-31-2018, 05:55 AM
stave7119's Avatar
The wider wheel track means the tires are outside the fenders and you get covered with anything you are driving through every time you ride. Or you can pony up for fender extensions which is another cost. The other thing is that some trails are limited to 50" wide machines. Most of the Polaris ATVs are all around 48" or less to start with. So when you add a couple inches on both sides, you end up over the 50" limit.
post #20 of 23 (permalink) Old 10-31-2018, 06:57 AM Thread Starter
gsxr150's Avatar
So if if don't ride on trails that are too tight and buy fender flares, then it should be pretty awesome right? Extra stability I imagine, and probably an outstanding look with the flares wheels...?
gsxr150 is offline
Wheel offset and bolt pattern dirtmuhgert ATV Wheels & Tires 6 09-27-2018 01:48 PM
Sportsman wheel offset Trailghost ATV Wheels & Tires 8 04-25-2018 04:27 PM
OEM steel wheel offset tac1 ATV General Discussion 8 02-28-2018 07:44 PM
wheel offset Smullz ATV Wheels & Tires 14 01-02-2018 06:45 AM
wheel offset?? joeblack ATV Wheels & Tires 16 05-08-2016 10:24 AM
