What is a 10mm offset? - Polaris ATV Forum
Sponsored by Discount Tire
post #1 of 23 (permalink) Old 10-23-2018, 08:17 AM Thread Starter
gsxr150's Avatar
Hi guys, I'm somewhat familiar with a 4+3 wheel being about 2 inches wider on each side... How about a 10mm offset? How much wider would that be?
I'm looking at these wheels: https://www.msawheels.com/product/wh...sh=satin-black
gsxr150 is offline
post #2 of 23 (permalink) Old 10-23-2018, 03:46 PM
burnsey166's Avatar
Well, 25.4mm is equal to 1 inch. So 3/8" is 10mm.
burnsey166 is offline
post #3 of 23 (permalink) Old 10-23-2018, 05:47 PM
bp405's Avatar
What are you putting them on?
2011 SportsmanŽ 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 SportsmanŽ 570-T
2019 AlumaŽ A8818
2020 OutlanderŽ 1000R XXC (on order, ETA mid-Sept)
bp405 is offline
post #4 of 23 (permalink) Old 10-23-2018, 05:52 PM
bp405's Avatar
Chk them out here: https://www.mudthrowers.com/inc/sdetail/27484/114539. They have them listed with the 4+3 offset. Plus mud throwers is a good retailer.
QSC clutch kit
added 7 zerks
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
2019 AlumaŽ A8818
bp405 is offline
post #5 of 23 (permalink) Old 10-23-2018, 06:29 PM Thread Starter
gsxr150's Avatar
2017 Sportsman 850 SP
gsxr150 is offline
post #6 of 23 (permalink) Old 10-24-2018, 03:44 AM
bp405's Avatar
Ok so IMO you don't want 4+3 on your wheeler.
QSC clutch kit
added 7 zerks
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
2019 AlumaŽ A8818
bp405 is offline
post #7 of 23 (permalink) Old 10-24-2018, 03:46 AM
bp405's Avatar
Chk out STI's HD series they make an almost stock 6+1 offset. Other then that again IMO 5+2 is as wide as you want to go on the XP chassis.
QSC clutch kit
added 7 zerks
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
2019 AlumaŽ A8818
bp405 is offline
post #8 of 23 (permalink) Old 10-24-2018, 05:41 AM
stave7119's Avatar
I have a 2018 850sp and I don't like the wheels. I haven't found anything else I like yet but I would agree that you want to stay as close to the stock offset as you can.
The offset on the stock wheels for the 2017 and 2018 850 is the same as on the Razor with the wheel center at the outside of the wheel. So if you put a 4-3 offset wheel on it that moves the wheel center back toward the inside of the wheel and will stick out way beyond the fenders. So then you will get covered with whatever you drive through.
2018 Kawasaki KLR650
SOLD 2004 Sportsman 600 Twin
stave7119 is offline
post #9 of 23 (permalink) Old 10-24-2018, 05:47 AM Thread Starter
gsxr150's Avatar
So is the offset on 2017 and 2018 850's slightly wider than a 2016? I'm not quite following, sorry...this is new to me.
Here are my thoughts. I'm "thinking" about doing the 2-inch highlighter kit and heard I might need a 1-inch spacer to offset the slight lift. No way I'm doing a crappy wheel spacer, so thought I would choose wheels that give me a little extra width. I though 2 inches higher and an inch or two wider would make good handling and get through deeper snow etc.
gsxr150 is offline
post #10 of 23 (permalink) Old 10-24-2018, 06:36 AM
bp405's Avatar
Why the lift??? You can get big tires on your ride. I mean if you are going to go through big skeg and snow I get it. But if it's just to be a more capable trail rig you might just want to consider bigger tires. Also if you go lift and tires axles are going to be needed also.
QSC clutch kit
added 7 zerks
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
2019 AlumaŽ A8818
bp405 is offline
Wheel offset and bolt pattern dirtmuhgert ATV Wheels & Tires 6 09-27-2018 01:48 PM
Sportsman wheel offset Trailghost ATV Wheels & Tires 8 04-25-2018 04:27 PM
OEM steel wheel offset tac1 ATV General Discussion 8 02-28-2018 07:44 PM
wheel offset Smullz ATV Wheels & Tires 14 01-02-2018 06:45 AM
wheel offset?? joeblack ATV Wheels & Tires 16 05-08-2016 10:24 AM
