Going up in tire size need little advice - Page 2 - Polaris ATV Forum
Sponsored by Discount Tire
 1Likes
post #11 of 12 (permalink) Old 02-21-2019, 07:18 AM
bp405's Avatar
So you said lift I think bigger tire is the better solution for your specific needs. Just remember guys go lift for larger diameter tires generally speaking. Cause the tire is what gets you away from the ground (ground clearance). I mean obviously a full suspension build with long travel a-arms etc etc will yield more GC but also with the intentions of adding bigger meats!!!! Just to clarify why I suggest 28" tires. Ok enough of me and my !!!
Like Mr. Bob stated the 4+3 rims will clear any diameter 9" wide fronts. You can go as wide as 12" on the rear. He also raises a good point about clutching!!! I believe it's a good idea at any big wheel kit 26" and greater. I also know that with the proper gear selection (L)ow you can run up to 28" tires that are obviously not 40+++ pounds a piece.
So bottom line your rig your $$$ your choice!!!! And if going kind of middle of the road is what you feel comfortable with then by all means!!! You have done your homework and your plan is a good one!!! Hey at the end of the day adding a big wheel kit is the best investment anyone can make to their wheeler IMO!!!
2011 Sportsman® 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsman® 570-T
2019 Aluma® A8818
bp405 is online now
post #12 of 12 (permalink) Old 02-21-2019, 03:00 PM Thread Starter
Polaris2012's Avatar
Thanks guys. Think I’m guna stick with the 26” so don’t have to go with a clutch kit. Still will look bad ass over anything stock
Polaris2012 is offline
Tire size question , advice needed thumpa ATV Wheels & Tires 10 12-30-2018 03:59 PM
DIY Tire Changing BeadBuster ATV Wheels & Tires 1 11-28-2016 04:04 PM
Larger tire size for Polaris 2006 450 help Newman0912 ATV Wheels & Tires 2 05-05-2016 03:00 PM
