3/8 to 1/2 - Polaris ATV Forum
Sponsored by Discount Tire
post #1 of 5 (permalink) Old 02-07-2019, 10:25 AM Thread Starter
Kingkat4's Avatar
3/8 to 1/2
I bought some ITP mags for the front of my 6x6 about a month ago and am getting around to using them. When I opened the box the stud holed are 1/2'' and my studs are 3/8'' when I called the dealer I was told that the tapered lug nits would be fine to use. I'm wondering about this, if I could find a sleeve that would fill the void I would feel better. I have looked at the hardware store with no luck for pipe or something I could use.
thoughts? thanks
If I'm wrong tell me so
Kingkat4 is offline
post #2 of 5 (permalink) Old 02-07-2019, 12:24 PM
bp405's Avatar
Yeah just use the tapered lugs!!!!!!! Believe me it's not an issue!!
2011 Sportsman® 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsman® 570-T
2019 Aluma® A8818
bp405 is offline
post #3 of 5 (permalink) Old 02-07-2019, 01:07 PM Thread Starter
Kingkat4's Avatar
Thank you a little reassurance is always nice.
Don
Kingkat4 is offline
post #4 of 5 (permalink) Old 02-07-2019, 01:19 PM
bp405's Avatar
The holes in the rim are oversized to give room for mounting then the tapered lugs center the rim on the hub.
QSC clutch kit
added 7 zerks
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
2019 Aluma® A8818
bp405 is offline
post #5 of 5 (permalink) Old 02-07-2019, 02:49 PM
Agreed - just use the tapered lug nuts
latebird is offline
2004 1/2 Sportsman 500 ho, puff of smoke from headlight Farone Polaris Sportsman 2 02-18-2018 05:33 AM
02 500 falls on its face at 1/2 throttle uper engine gasket install pci24 ATV Repair and Maintenance 3 10-05-2017 07:19 AM
04 1/2 Sportsman 600 backfires won't run without choke turbowrenchhead ATV Repair and Maintenance 1 03-28-2017 09:47 AM
2004 1/2 500 sportsman fan and light problem krsrp ATV Repair and Maintenance 0 08-04-2016 06:46 PM
1/2 a rear cargo box BTH ATV Visual & Body Modifications 2 05-24-2016 02:25 PM
