Bigger tires on stock rims. - Polaris ATV Forum
Sponsored by Discount Tire
post #1 of 3 (permalink) Old 05-20-2019, 08:38 PM Thread Starter
Adkrider114's Avatar
Hey guys. I know the wheel and tire questions are constantly and I have searched the forums greatly looking for an answer here. I just picked up a 2016 sportsman 570 base and I would like to install some bigger tires. However every discussion I come across advises to replace the rims to be able to clear the tie rod ends with the bigger tires. My problem is I have a ram truck with the ram boxes so my bed width is only I believe 49.5 inch max. I Have a ranger but bought the sportsman so I can haul in the truck so offset rims are not an option. So my question is what size tires can I actually run on this thing without a lift or offset rims?
Adkrider114 is offline
post #2 of 3 (permalink) Old 05-22-2019, 07:20 AM
bobx2's Avatar
You are going to have to stay with an 8" wide front tire, regardless of the height, if you want to keep it under 50" wide. Unfortunately, there is no magic solution for fitting bigger tires without adding width to your 570.
2018 Polaris General 1000, Elka Stage 2 Shocks, 29" Tusk Warthogs, Polaris 4,500 lb. winch, Factory UTV Skid Plates, Dux Turn Signal/Horn Kit, EMP Cooter Brown Roof, Ryfab Folding Glass Windshield, Spring Brake Thingy
2015 Sportsman 570 Touring EPS, 26" Kenda Bearclaw HTR's on ITP Delta Steel wheels, Warn Vantage 3000, Elka Stage 1 Shocks, Warn Mid-Mount Plow (Wife's)
bobx2 is offline
post #3 of 3 (permalink) Old 05-22-2019, 06:49 PM
stave7119's Avatar
Yep, most aftermarket tires come in 9" wide front. Not sure why they don't match what comes on the machines from the factory, but they don't. So right there you will add 1/2 inch to the overall width and probably rub the tie rod ends on the inside. 1/4" spacers can solve that issue, but now you will be at or over your max width for the truck bed. The other choice is an aftermarket wheel but the offset and backspace will be different so your total width will again be at or over 50"
Sorry, I don't have any good solutions for you.
Hers: 2007 Sportsman 500 EFI, Polaris Winch, 26" Bear Claw HTRs on Moose 427x Wheels. QSC Clutch Kit, Hand Warmers
2001 Magnum 325 Warn winch and Moose 60" plow
SOLD 2004 Sportsman 600 Twin
stave7119 is online now
New tires - stock rims jobofly Polaris Sportsman 570 8 01-18-2019 03:04 PM
Stock Polaris 570 SP rims and tires! $$? PsycoJuana Around The Garage 5 05-23-2016 03:48 PM
Replacement tires on stock 570 rims bmallak ATV Wheels & Tires 3 03-06-2016 01:17 PM
wanted Stock XP 1000 tires and rims or just tires adspipe ATV Parts Wanted 0 03-01-2016 04:39 PM
Stock wheels, bigger tires TexasSportsman ATV Wheels & Tires 2 11-26-2015 04:43 AM
