850SP Touring - Removing & Replacing Passenger Seat - Polaris ATV Forum
Polaris ATV How-Tos Polaris ATV How-Tos, Guides, FAQs put together by the PolarisATVForums.com membership.
post #1 of 10 (permalink) Old 05-29-2017, 08:13 AM Thread Starter
boulderskies's Avatar
Question 850SP Touring - Removing & Replacing Passenger Seat
My brand new 2017 Sportsman 850 Touring (2 seats) does a lot of things well but there is one thing that befuddled me for hours (literally): Removing & Replacing the Passenger Seat. It could just be me but I dont think so. Anyway, here're concise step by step instructions (that dont exist anywhere).
REMOVING
1. Position yourself directly behind the bike, one hand on top of passenger seat, one hand on handle at bottom of seat.
2. Simultenously push down with hand on top of seat and pull UP on handle, and lift.
(there's a silly strap, metal plate that the handle is supposed to pull away to unlatch the seat; it takes some doing)
REPLACING
1. Place seat down into its position, with bottom seat cushion tilted down slightly and pushed against operator seat.
2. Grasp metal arm rests right next to either side of seat.
3. Push forward and down.
(this last move took me almost an hour to figure out...practice it, you'll get better at it)
BONUS
Undocumented (at least as far as I can tell) is a storage area under the passenger seat cushions. You access it by grasping the front of the cushion and YANKING UP.
I seriously hope this will help others.
Scott
2017 Sportsman 1000XP Touring
Pine, AZ
boulderskies is offline
post #2 of 10 (permalink) Old 01-05-2018, 04:02 PM
Doc8404's Avatar
Originally Posted by boulderskies View Post
BONUS
Scott
without removing the seat? Just the bottom comes up?
2018 Sportsman Touring 850 SP
Delivery 12/22/2017.
Polaris 3500 winch.
Cabela's Deluxe ATV Cover, size XXL.
Polaris handguards and mount.
Guru CTR1 with middle mesh and CF3. Ordered 12/22/17. Recíd 1/26. Installed 2/4 without lower bolts.
IB HDPE skids. Shipped 1/9. Rec'd 1/11. Installed 1/14.
Doc8404 is offline
post #3 of 10 (permalink) Old 01-10-2018, 03:25 AM
Doc8404's Avatar
Does not appear that just the bottom comes off. Whole seat does and I guess you could store stuff there.
Polaris 3500 winch.
Doc8404 is offline
post #4 of 10 (permalink) Old 01-10-2018, 01:10 PM
thumper1500's Avatar
Both. The whole seat comes off, thought as noted, it can be sticky. ALSO, the seat cushion can be popped up in the front and then removed to expose a fairly small but handy additional storage area in the seat itself. Note that you need to be careful removing the seat cushion - I broke a tab off not doing it right. You pull up on the front only to pull two plunger knobs out of rubber grommets, then stop pulling up and wiggle it forward to allow two plastic tabs at the back to slide out of their slots.
2015 Sportsman XP 1000 Touring
Bronze Mist
QSC Clutch Kit
Ricochet Ultimate Armor Kit
HighLifter 2" lift kit
Kenda Bearclaw HTR 28" tires
Cecco frame braces
Cecco billet front pinion cover
Guru silver bumpers
12" LED lightbar
2" hitch w/bottle opener
Mid smoke windshield
Tatou 4s tracks for the snow
Synth winch line and Hawse fairlead
LED headlights
Wired for electric helmets
thumper1500 is offline
post #5 of 10 (permalink) Old 01-11-2018, 05:09 AM Thread Starter
Cool
I didnt think it did either but I finally figured out that I had to get really tough with it when I basically tore the seat cushion off, as described here. Wear gloves, that helps a lot...
Pine, AZ
post #6 of 10 (permalink) Old 03-17-2018, 02:05 PM
NH_Rider's Avatar
Is there are cover you can buy for when the rear seat is removed? I see it in some craigslist adds but not in the polaris accessories section on their website.
NH_Rider is offline
post #7 of 10 (permalink) Old 03-18-2018, 04:18 AM Thread Starter
Cool
See video at: https://www.polarisatvforums.com/foru...1000-a-21.html for a very homemade solution. I'm thinking a carefully cut and fitted piece of plywood with the foam shown in the video might also work.
Pine, AZ
post #8 of 10 (permalink) Old 03-18-2018, 06:22 AM
NH_Rider's Avatar
Thank you Boulderskies. I had seen that one and it is an interesting approach. I do wood working so may try this one. I know there is a piece you can buy from Polaris for the older models that provides a small compartment when the seat is out. I would expect it to be available in a year or two. In the mean time I will build something because when I do my longer trips, I want the rear seat off.
NH_Rider is offline
post #9 of 10 (permalink) Old 03-18-2018, 08:35 AM Thread Starter
Cool
I would wager that plywood solution is going to one heckuva lot cheaper than whatever the geniuses at Polaris come up with. I was unable to find a Polaris solution for a rear cargo box for my 1000XP Touring so I cut a piece of plywood to fit in the alcove above the license plate, screwed it into place (with toggle anchors using existing holes) and used big zip ties to hold a milk crate to it. A certain size RubberMaid cooler fits perfectly inside the crate. See pics below...
ID:	103490   Click image for larger version
Pine, AZ
post #10 of 10 (permalink) Old 03-18-2018, 11:16 AM
NH_Rider's Avatar
There you go. Quick and functional.
NH_Rider is offline
Go Back   Polaris ATV Forum > Polaris ATV Technical Discussions > Polaris ATV How-Tos
Sportsman 850 Touring Rear Seat Question Skeld Polaris Sportsman 27 11-05-2017 06:38 AM
2017 850SP Touring - Check Engine Light boulderskies ATV Repair and Maintenance 6 06-12-2017 04:39 PM
2012 850 touring passenger seat cover plate 79786 Polaris Sportsman 6 07-13-2016 06:48 PM
Best cargo/passenger seat for 2016 sportsman 850sp Emaisch1080 ATV General Discussion 20 06-02-2016 12:06 PM
Couldn't find a passenger seat I liked so I made one rtoms Polaris Sportsman 570 7 04-02-2016 01:37 PM
