2008 sportsman 400 HO clutch removal - Polaris ATV Forum
Polaris ATV How-Tos Polaris ATV How-Tos, Guides, FAQs put together by the PolarisATVForums.com membership.
 2Likes
  • 1 Post By fc4296
  • 1 Post By fc4296
post #1 of 10 (permalink) Old 05-06-2019, 07:25 PM Thread Starter
fc4296's Avatar
Any tips or tricks to getting this clutch removed. It has the nut holding it on instead of the threaded rod that most clutches seem to have. There's really no place to insert a rod to keep it from spinning while I loosen the nut. Any ideas greatly appreciated.
fc4296 is offline
post #2 of 10 (permalink) Old 05-06-2019, 07:29 PM
indyred570's Avatar
Impact?
Doesn't look like an OEM clutch.
2014 Sportsman 570
Powermadd Hand Guards
Viper Elite 3000 Winch/KFI mount
Denali Snow Plow
Polaris HD Front Springs
Kenda Executioners
Ricochet A-arm guards
QSC clutch kit
indyred570 is offline
post #3 of 10 (permalink) Old 05-06-2019, 07:33 PM
FPD218's Avatar
Put a large zip tie around the belt from top to bottom, between the primary and secondary pulleys and squeeze the belt as tight as you can get it....... use a impact gun, with transmission in park, that should hold it from spinning
JUNE 2017 & SEPTEMBER 2018 POLARIS FORUM ATV OF THE MONTH WINNER
2019 Sportsman 850 SP Premium
Removed all Warning Decals
3500# Polaris Winch W/Synthetic Rope
Winch Stopper Cable Line Saver
ATV-GURU.COM Front and Rear Bumpers
2" Receiver in Front Bumper
Kenda K587 HTR Bear Claws 26X9X14 & 26X11X14
Ultimate Series Windshield Fairing, Mid & Low Height Windshield
New Style Polaris Lock & Ride Rear Storage Box
Garmin GPS176C, Ram Mount
Polaris Rear View Mirrors
4" Front Rack Extender
Center Brake/Tail Light LED
Rear LED work lights/strobes
Built on March 27 2019
Purchased New April 13 2019 0.1 Hr .2 Mi
Power Sports Abrams, Wi
SOLD
2006 Sportsman 800 EFI Twin
Purchased new to me on Aug 08 2016 97Hr's 811Mi
Sold Apr 07 2019 231 Hr 3126 Mi
https://www.youtube.com/watch?time_c...&v=k6Nlb_qRoeg
"I am the majority!"
*WEAR A HELMET, I'M LIVING PROOF THEY WORK!
FPD218 is offline
post #4 of 10 (permalink) Old 05-06-2019, 07:33 PM Thread Starter
fc4296's Avatar
I can't keep it from spinning as I try to loosen the nut. Clutch is original as I bought the machine new. Saw the same clutch on pics of a 2007 hawkeye 300.
indyred570 likes this.
fc4296 is offline
post #5 of 10 (permalink) Old 05-06-2019, 07:34 PM Thread Starter
fc4296's Avatar
Thanks FPD218, I'll give that a try!!!!
FPD218 likes this.
fc4296 is offline
post #6 of 10 (permalink) Old 05-07-2019, 05:29 AM
No puller is needed - the clutch assembles piece by piece like most all Chinese clutches
latebird is online now
post #7 of 10 (permalink) Old 05-07-2019, 05:55 AM Thread Starter
fc4296's Avatar
Even though it comes off piece by piece I still need to get the nut off the shaft. Unfortunately the way it's designed I cant keep the clutch from spinning like almost ever other clutch on the market. I've tried everything and looked for tools to help. I cant find anything. Posting here because I know you guys know all the tricks and hopefully this helps some moron like me in the future.
fc4296 is offline
post #8 of 10 (permalink) Old 05-07-2019, 06:33 AM
I just use an air impact driver and no holding tool is needed - Polaris does offer special tools, but with an impact wrench the holding tools are not needed - the nut has an integral collar that is peened into a recess on the crankshaft to prevent it form loosening - it is recommended the nut be replaced each time it has been peened and removed - it is not always necessary because it doesn't always stop in the same place and many times it stops in an unused portion of the collar, but it's a good idea to get a nut just in case it's needed - may not be needed this time , but almost certainly will the next time it's removed
post #9 of 10 (permalink) Old 05-07-2019, 06:41 AM Thread Starter
fc4296's Avatar
Thanks Latebird, I'll give that a try.
fc4296 is offline
post #10 of 10 (permalink) Old 05-14-2019, 04:00 PM Thread Starter
fc4296's Avatar
Tried an air impact gun and it didn't work. Probably my small pancake air tank. Borrowed my neighbors DeWalt electric impact gun and it came off in seconds!!!!
fc4296 is offline
Go Back   Polaris ATV Forum > Polaris ATV Technical Discussions > Polaris ATV How-Tos
VIN - Sportsman 500 or 500 HO? das86turbo ATV Repair and Maintenance 7 01-02-2019 06:58 AM
