06 polarissportsman 500 HO not charging - Polaris ATV Forum
Polaris ATV How-Tos Polaris ATV How-Tos, Guides, FAQs put together by the PolarisATVForums.com membership.
post #1 of 8 (permalink) Old 08-16-2019, 12:01 PM Thread Starter
banshee61067@gmail.com's Avatar
I have a sportsman 500 4x4 that isn't charging and the battery symbol flashes
Last edited by [email protected]; 08-16-2019 at 12:10 PM. Reason: Didn't put full question in
post #2 of 8 (permalink) Old 08-16-2019, 12:14 PM Thread Starter
Hello, I new here but have a sportsman 500 ho 4x4 non efi and have charging problems, I have tested battery with quad not running and it was reading 12.5 volts- battery is new. When I start it at idle the voltage reads 17.8 volts at the battery and that's sounds like it might be a voltage regulator problem, any help would be appreciated thank youbattery
post #3 of 8 (permalink) Old 08-16-2019, 06:46 PM
I believe you need to replace the rec/reg before the high voltage damages the battery
latebird is offline
post #4 of 8 (permalink) Old 08-17-2019, 07:25 AM Thread Starter
Thanks, that's what I thought and I have already ordered it, on a side note the cooling fan stopped working as well.
post #5 of 8 (permalink) Old 08-17-2019, 09:01 AM
What year model
latebird is offline
post #6 of 8 (permalink) Old 08-17-2019, 10:26 AM Thread Starter
2006 sportsman 500 ho non efi 4x4
post #7 of 8 (permalink) Old 08-17-2019, 12:20 PM
The fan is controlled by the rec/reg - it's referred to as the Sure Power unit - part # 2203348 @ $150
latebird is offline
post #8 of 8 (permalink) Old 08-17-2019, 12:38 PM Thread Starter
Yes, in researching the problems I found the even incorporates fan operation in the ecm as well, that is the part number I looked up for it and found a new oem one in box for $149.95. I ordered it this morning
Go Back   Polaris ATV Forum > Polaris ATV Technical Discussions > Polaris ATV How-Tos
