Troubleshooting 2006 Sportsman 700 Fuel Pump, Fuel Gauge, and Fuel Pressure Regulator - Page 3 - Polaris ATV Forum
Polaris ATV How-Tos Polaris ATV How-Tos, Guides, FAQs put together by the PolarisATVForums.com membership.
post #21 of 27 (permalink) Old 07-24-2016, 01:44 PM
twostarrz's Avatar
The sending unit should read a differential of resistance much like a rheostat. I would replace it.
Mine - 2013 polaris sportsman 800. 28x9x12 and 28x11x12 ITP mega mayhems on 12x7 ITP black steel wagon wheels, 4500# venom winch, rear tool box.
Hers - 2008 Yamaha wolverine 450. 26x12x12 super grip super lites rear, 26x9x12 super grip super lites front, 1 1/2" spacers all the way around, pro mark 3000# winch on custom mount, HMF pipe, K&N air filter, jet kit, custom rear rack with seat/toolbox and 5 gallon gas can mount.
Daughter - 1999 polaris scrambler 500 4x4. 22x12x10 bear claws rear, 23x7x10 bear claws front, reinforced rear swing arm (long story), 4" lift kit in rear, 3000# promark winch on custom by me front bumper, rear cargo box.
Sons - 2000 polaris scrambler 400 4x4. 22x12x10 bear claws rear, 23x7x10 bear claws front, 4" lift kit in rear, rear cargo box
Sold:
2004 Yamaha warrior 350
1999 Yamaha blaster 240 big bore
1995 kawasasaki Mojave 250
2001 Polaris sportsman 90
2008 kolpin 90
1985 Suzuki lt250R quadracer
twostarrz is offline
post #22 of 27 (permalink) Old 07-24-2016, 03:46 PM
EricB's Avatar
My sending unit looks different than the others that have been posted so I don't think I can use the part number that is posted in the thread. Any ideas on if there is one available without buying the entire tank assembly? Thanks for the help.
EricB is offline
post #23 of 27 (permalink) Old 02-21-2018, 07:14 AM
Phearless's Avatar
Originally Posted by fishhooker View Post
2006polar500, it sounds like your sending unit is toast. Check your fuel pressure to see if your pump is going out and causing the sputtering
Here's a quick fix for the broken clip on the fuel pressure regulator discussed above by AKStew. Just a hose clamp with a hole punched in it to go over the unused vac port. Be sure to get all stainless, marine grade, clamps. The ethanol can corrode the screw on standard clamps. See the pics.
What if you break/lose the regulator housing/holder, is there another one you can buy or use off another application?
Phearless is offline
post #24 of 27 (permalink) Old 07-04-2018, 03:57 AM
slva2000's Avatar
Pressure regulator: Bosch 0280160585 - 2.7 bar (~39 PSI).
slva2000 is offline
post #25 of 27 (permalink) Old 09-10-2018, 05:58 PM
Billythekid_ny's Avatar
Highflowfuel.com great site. Just put in your year make and model you got your parts! Try it out. Worked great for me.
Billythekid_ny is offline
post #26 of 27 (permalink) Old 10-01-2018, 05:37 PM
2004 Polaris sportsman 700 EFI
I have a 2004 Polaris sportsman 700 EFI. Changed out the fuel pump, put everything back together and it wont start with out my hand over the intake. As soon as I take my hand off or let just a little bit of air in it shuts off. What could be the trouble.
Before I put it all back together I put the pump in a bucket of gas and it fired right up and idled for about 30 seconds before I shut it off.
post #27 of 27 (permalink) Old 04-13-2019, 04:41 PM
Usramc's Avatar
Billythekid_ny you ever figure yours out? I’m having the same issue, just put in a new carter pump but now I’m only getting 5 volts to it.
Usramc is offline
Go Back   Polaris ATV Forum > Polaris ATV Technical Discussions > Polaris ATV How-Tos
Guide to Servicing the Fuel Pump, Gauge & Regulator - 2006 Sportsman 700 EFI AKStew ATV Repair and Maintenance 60 05-27-2016 08:52 AM
Fuel Pressure Regulator--Suitable Substitute?? AKStew ATV Repair and Maintenance 23 02-10-2015 01:04 PM
04.5 700EFI fuel pressure regulator ? D Bunce ATV Repair and Maintenance 3 02-03-2015 06:05 PM
Fuel Pressure Regulator Part Number? '06 700 EFI AKStew ATV Repair and Maintenance 0 09-25-2011 11:37 AM
04.5 700EFI fuel pressure regulator ? D Bunce Polaris Sportsman 0 06-13-2011 06:51 AM
