Oil dripping down from headlight. 06 HL1000 - Page 2 - Polaris ATV Forum
Polaris Highlifter Discuss the new Polaris Highlifter 850 and Highlifter 1000
 2Likes
post #11 of 18 (permalink) Old 06-03-2018, 01:11 PM Thread Starter
Skipholiday's Avatar
I was cleaning it up and getting ready for the shop. Notice the oil is coming from the crankcase or it looks like a vent tube on the front of the starter.
ID:	110457   Click image for larger version
ID:	110465   Click image for larger version
if your outgo exceeds your income your upkeep will be your downfall.
Skipholiday is offline
post #12 of 18 (permalink) Old 06-03-2018, 01:15 PM Thread Starter
Originally Posted by shane-o View Post
if you do find oil in the vent line between eng and trans don't drive it until fixed, it will cause the spike load dampener to swell and actually pushes on the crank shaft and will wear the lower engine cases where the crank shaft sits it could be trans oil ? but would be a really dark or purple colour if it was the trans, likly the rear diff is vented in the pod to ? due to it being a high lifter model
Originally Posted by Gulf550 View Post
Well the first thing I would do is start looking at the vent lines. A vent comes from the starter case area. It's the part the couples the engine and transmission together. You can see it if you take your seat off. It's possible a rear main seal went on the engine or the transmission input shaft seal went. You have another vent from your rear diff and transmission. They T together right under the seat. Can't imagine the rear diff or transmission vent being the culprit. You have another vent off your front diff. The high lifters do something weird with the fuel tank vent I believe. I think it runs to a Y fitting? I would check the starter case area good. It only makes since it would be coming from that area unless your airbox is full of oil?
Looks like its the one coming from the starter case area. I will clean it up and get it ready for the long drive to the shop.
post #13 of 18 (permalink) Old 06-03-2018, 04:39 PM
shane-o's Avatar
yup take it in rear main seal likely leaking?
Skipholiday likes this.
2015 xp 1000 black pearl,
-polaris front and rear bumpers
-polaris hand/thumb warmers
-polaris body guard
-gse slip on
-front diff fix
-cecco frame braces
-lock and ride front box.
-dobeck fuel controller
-big horn originals/mega mayhems depending on the ride
shane-o is offline
post #14 of 18 (permalink) Old 06-13-2018, 04:56 PM Thread Starter
Cleaned my Highlifter up real good before the long ride to the shop,
After cleaning I took it for a ride in the hay field beside my house to dry it off.
I pud a clean white rag underneath the headlight pod to keep any oil from dripping down and getting it nasty again.
After the drive I noticed there was no oil on the rag. I drove it more and the tube with the dark oil in it had become clear again.
Checked crankcase and it still has fluid, ( I ordered new to change)
Buddy of mine said he had seen differentials foam up when they got hot.
So the guess is that it had enough mud on it to make it run hot and blow out the vent.
So far 3 days and all is good.
Thanks for all the help and insight.
post #15 of 18 (permalink) Old 06-14-2018, 04:10 AM
MustBeNice's Avatar
The vent lines are usually clear tubing.... do any of them running into the pod show up darker (due to having oil/lube in them) then the others?? You could trace it back to the source component then....
Pressure (blow by) in the crank case?
Is the "Breather" to the air box plugged?
Good luck.... let us know what you figure/find out!!!
Matthew "MustBeNice"
MustBeNice is offline
post #16 of 18 (permalink) Old 06-14-2018, 04:21 AM Thread Starter
You must have missed the beginning of the discussion. It was oil coming from the clear vent and dripping from my light pod. Traced the vent to the one coming from the crankcase above the starter (pics are posted). Vent tube was totally dark and full. Was preparing to take to dealer and washed it up real good. Drove to dry it off and noticed the oil had quit dripping. Drove longer and the vent tube is now back clear. Possible cause was heat making the oil foam and blow out the vent. Crankcase still has oil and ordered complete fluid change.
post #17 of 18 (permalink) Old 06-14-2018, 07:37 AM
Gulf550's Avatar
The concern I would have is, it could be your rear main engine seal or your transmission input shaft seal. As a piece of mind I would change the transmission oil as well.
The tube that showed the discoloration should have no fluid in that housing. If it was foaming in your rear diff or transmission, he should have came out a different tube.
Gulf550 is offline
post #18 of 18 (permalink) Old 10-14-2018, 04:40 PM Thread Starter
We got the highlifter back from the dealer for the heat shield recall.
We changed all fluids and it still leaked from the vent tube. I drive 90% of the time in low.
I decided to drive a while in high. It stopped pushing oil through the vent tube. Only does it in low.
Go Back   Polaris ATV Forum > Polaris Model Specific Discussions > Polaris Highlifter
ASM-CLUSTER,110MM,W/FUEL (Speedo Cluster) FOR SALE KLCFLC Polaris Sportsman 2 02-18-2019 05:57 PM
3280431 ASM-CLUSTER,110MM,W/FUEL (Speedo Cluster) KLCFLC ATV New Members 1 09-18-2017 07:52 PM
Oil drain plug dripping Liftedpsd ATV Repair and Maintenance 4 08-21-2017 02:54 PM
2014 Sportsman 570 Oil-Filters rotor Polaris Sportsman 570 23 06-01-2017 05:16 PM
2006 Ranger 700 XP Rebuilt, Oil on top of pistons liquidcourage ATV Repair and Maintenance 3 01-02-2017 03:26 PM
