Bleeding air from coolant - Polaris ATV Forum
Polaris Highlifter Discuss the new Polaris Highlifter 850 and Highlifter 1000
 2Likes
  • 1 Post By autosport7
  • 1 Post By bp405
post #1 of 5 (permalink) Old 08-16-2018, 12:59 PM Thread Starter
Liftedpsd's Avatar
Hey guys had to take the radiator off the highlifter to clean it really well before I install the rogue radiator cover. What the the easiest way to bleed all the air out of the coolant system? Thanks.
Liftedpsd is online now
post #2 of 5 (permalink) Old 08-16-2018, 03:27 PM
autosport7's Avatar
Iíve seen people burp the system, meaning they squeeze the top hose as they pour it in.
Iíve seen people pull the bottom hose while they pour in and once it starts coming out the bottom they put the bottom hose back on.
Iíve seen people leave the cap off for the first 30-45 seconds after refilling and starting.
Some vehicles have drain plugs you can pull until it starts coming out.
Iíve also seen people reverse feed fluids from bottom up.
Iíve seen people do a combination of a few Iíve listed.
Liftedpsd likes this.
2015 Polaris Scrambler XP1000
Red Bull Graphics Kit
Spider Graphix - Footwell Dacals
Mud Motorsports Gripper Seat Cover
Rogue Grille - Blk/Blk/Red
Pure Polaris Hand Warmers
Pure Polaris Thumb Warmer
GBC Grim Reaper - 26/9/14 - 26/11/14 on Hiper Sidewinder Beadlocks
All Balls Wheel Bearings FR/RR
ROX Speed FX Foot Pegs
CECCO Frame Braces FR/RR
CECCO Diff Cover
Uni Air Filter
EPI Clutch
Big Gun Exhaust
Moog SSB Upgrade W/ Custom Zerk
Powermadd Sentinel Handguards
Renthal G169 Grips
Gear
Leatt 5.5 V.05 Turbine - Helmet
Oakley Airbrake - Goggles
EVS Sport - Chest/Back Protector
OGIO Dakar - 3L Hydration Pack
Shift Recon - Pants/Jersey/Gloves
Alpinestars MXGP - Jersey
Alpinestars S-MX Air Carbon Mesh - Gloves
Alpinestars Tech 8 - Boots
autosport7 is offline
post #3 of 5 (permalink) Old 08-16-2018, 04:50 PM
bp405's Avatar
Generally elevate the front of the machine 15-20 inches off the ground, leave the cap off, bring the engine up to operating temperature (thermostat open), and let it cycle (thermostat opening and closing) a few times
2011 Sportsmanģ 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsmanģ 570-T
2019 Alumaģ A8818
bp405 is online now
post #4 of 5 (permalink) Old 08-16-2018, 04:51 PM Thread Starter
Liftedpsd's Avatar
Ok thanks guys. I wasnít sure if it mattered that the radiator was up top on the rack and didnít know if I had to do it different.
Thanks.
post #5 of 5 (permalink) Old 08-16-2018, 06:09 PM
Mike_B's Avatar
On anything ive owned i just take the radiator cap off and run the engine till it gets hot. You will see when t-stat opens because fluid level in the radiator drops.
Once the stat opens and the level drops, top it off with coolsnt and let it run a few minutes to bleed all the air out.
Sent from my SM-G930V using Tapatalk
Mike
Mike_B is offline
Go Back   Polaris ATV Forum > Polaris Model Specific Discussions > Polaris Highlifter
2002 Polaris Sportsman 700 Twin Ė Oil & coolant mixing BillTheBuyer ATV Repair and Maintenance 10 03-23-2019 06:15 AM
2002 Polaris Sportsman 700 Twin Ė Oil & coolant mixing BillTheBuyer ATV Repair and Maintenance 0 10-10-2017 12:12 PM
coolant system port ATV General Discussion 3 07-05-2017 09:42 AM
scrambler 400 coolant bleeding scrambler02 ATV Repair and Maintenance 0 04-28-2017 07:19 PM
2015 570 Coolant Question BlueFire570SP Polaris Sportsman 570 16 08-26-2016 01:36 PM
