Starter motor - Polaris ATV Forum
Polaris Highlifter Discuss the new Polaris Highlifter 850 and Highlifter 1000
 3Likes
  • 2 Post By latebird
  • 1 Post By bp405
post #1 of 5 (permalink) Old 03-18-2019, 01:20 PM Thread Starter
gearheadesw1's Avatar
Starter motor
I'm having a hell of a time getting my starter out. The top back bolt is near inaccessible, haven't been able to get it off with many many cuss words thrown at Polaris for even putting the bolt in there like that, truly what the fuck!!!!!!
must modify
gearheadesw1 is offline
post #2 of 5 (permalink) Old 03-18-2019, 02:04 PM Thread Starter
Got it out, wasn't the problem, smashed 4 wheeler with truck putting it back on to parking spot. Fucked it all up. Probably won't be back for quite a while. whew, for you guys.
must modify
post #3 of 5 (permalink) Old 03-19-2019, 06:31 AM
Obviously not cut out to be a mechanic and failed to read the service manual - all you have to do is remove the outer clutch cover, remove the clutches and the inner clutch cover - no cussing and a simple job kept simple - of course you can cheat if you are dexterous and smarter than the machine - sounds like you are a person I hope to never meet on the trails - garage rage gives rise road rage
FPD218 and gearheadesw1 like this.
2006 Trailboss 330
2002 Sportsman 90
2005 TRX400EX (FOR SALE)
2004 CRF250X
1979 Honda CBX (6 cylinder)
1981 Kawasaki KZ305-A
1989 Honda VT1100C
latebird is online now
post #4 of 5 (permalink) Old 03-19-2019, 02:16 PM
bp405's Avatar
opco rn::cus sing:
gearheadesw1 likes this.
2011 Sportsman® 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsman® 570-T
2019 Aluma® A8818
bp405 is offline
post #5 of 5 (permalink) Old 05-06-2019, 07:06 AM Thread Starter
My manual has something completely different than what you're seeing. The rear bolt was a bitch, bunch of extensions and wobblies, then it was a low battery and a loose connection. So all that drama and it's running, broke another axle, drag.
ID:	117657   Click image for larger version
must modify
Go Back   Polaris ATV Forum > Polaris Model Specific Discussions > Polaris Highlifter
Polaris Outlaw Starter shredding gears aaron.jackson Polaris Outlaw 3 08-27-2018 07:27 AM
Weird Starter question davis911s Polaris Sportsman 13 01-17-2018 03:22 PM
2012 Polaris 550 won't start Areebkh1 ATV Repair and Maintenance 6 11-27-2017 07:45 AM
330 (4x4) Magnum 2003 Starter spins, but starter drive assy. won't engage into flywheel? Gunzo Polaris Magnum 3 10-22-2017 12:57 PM
Trailblazer 250 Starter is bad, possibly something else too? jm91rs ATV Repair and Maintenance 0 04-18-2016 06:58 AM
