1997 Polaris Magnum 425 4x4 - Polaris ATV Forum
post #1 of 8 (permalink) Old 05-29-2011, 11:30 PM Thread Starter
lemans81's Avatar
Ok I just received a 1997 Polaris Magnum 425 4x4, from my late uncle. Now it has a few issues that I am wondering about. It has about 3500 miles on it now.
1. What maintaince needs to be done and how often, I would guess it will see about 25 miles a year worth of use, and be stored in a climate controlled garage. But I would guess its been many years since anything has been done to it.
2. Where is the best place to pick up replacement parts reasonably priced, it needs the coolant tank, the 90 degree nipple, and a new hose. It also needs the plastic cover that covers the rear disc brake.
3. At some point the 4x4 failed, and he removed the front chain. And to make it work he has a wire holding the override button down...is this acceptable? If not is it worth really fixing the 4 wheel drive or not?
lemans81 is offline
post #2 of 8 (permalink) Old 05-30-2011, 06:48 AM
Beenthere's Avatar
Welcome!
This is a great forum!
I have a 95 425 Magnum that I picked up awhile ago, after alittle TLC, this quad is Great!! Yes, it's worth fixing the 4 wheel drive. This thing will go places you wouldn't think you could go.
The first thing I would do is change all the fluids and change all of filters and spark plug. You can get basic parts at any auto parts store. For the other parts, Ebay or some other places online, also would be a good idea to find a good Polaris dealer nearby.
As far as maintainance goes, it depends on how and how much you ride. Just keep an eye on the quad and this should last for years.
Good Luck!
95 Magnum 425 4X4
Beenthere is offline
post #3 of 8 (permalink) Old 05-30-2011, 10:45 AM Thread Starter
lemans81's Avatar
Mine actually looks just like your avatar. I just don't know whats wrong with the 4x4, and fixing it is probably outside the budget.
lemans81 is offline
post #4 of 8 (permalink) Old 07-18-2011, 10:40 AM
cw8
cw8's Avatar
I'd like to add that you can safely take the wire off of the Override button, as it is only for engaging the AWD when you go reverse!
cw8 is offline
post #5 of 8 (permalink) Old 07-19-2011, 06:02 AM
stefanj's Avatar
Depending on WHY the AWD failed, will detirmine if it's in your budget. If your mechanically inclined (I'm not so I would not be able to fix it)you can take the system apart and often a good cleaning and some new seals are all that is required. As for maintence- well you can get the owners manual (Polaris may even supply it free if you contact them) and follow the recommended service intervals. As for replacement parts- Well Google is going to be your best friend here. Lots of good supply houses online. Also try to find a good local dealer as they can be very valuable when it come to hard to find parts. You got a good machine! Worth the time and effort (and money) to fix it up!
03 Magnum 330 4x4 Mossy Oak
Cycle Country 48" plow
Superwinch LT2000
GuideGear rear drop rack basket
Koplin seat cover
Front and rear rack bags
rear tire chains
rear work light (walmart)
8 acres of personal riding space
stefanj is offline
post #6 of 8 (permalink) Old 03-13-2012, 11:45 AM
rickricotti's Avatar
where can I get an owner's manual for a 1997 magnum 4x4?
rickricotti is offline
post #7 of 8 (permalink) Old 05-23-2019, 06:36 PM
l.flor1130's Avatar
Manual
I picked up a shop manual for 85-97 from Haynes All I need for my 97 Magnum 425 6X6
l.flor1130 is offline
post #8 of 8 (permalink) Old 05-24-2019, 07:28 AM
stave7119's Avatar
The first thing to do with the AWD is change the fluid in the hubs. Easy and only costs the price of a quart of ATF. Pull the front wheels off and take out the allen head plug. Look for debris on the magnet. Turn the hole down and drain them. Fill again and turn the hole to about 3 o'clock and let it drain out until it stops. Put the plug back in and try them.
They are picky about having clean fluid in them.
Hers: 2007 Sportsman 500 EFI, Polaris Winch, 26" Bear Claw HTRs on Moose 427x Wheels. QSC Clutch Kit, Hand Warmers
2001 Magnum 325 Warn winch and Moose 60" plow
SOLD 2004 Sportsman 600 Twin
stave7119 is online now
1997 polaris magnum 425 4x4 transmission fluid baner06 Polaris Magnum 4 05-25-2011 05:42 PM
1997 magnum 425 4x4 ? Boom ATV Repair and Maintenance 14 05-11-2011 03:39 PM
1997 Magnum 425 JohnII ATV Purchasing and Price 4 05-10-2011 03:58 PM
HELP HELP on demand drive 1997 425 magnum Pas Bon ATV Brakes & Suspension 1 12-18-2009 04:06 PM
1997 polaris 425 magnum front hub locking Alex ATV New Members 8 12-17-2009 03:17 PM
